H-Series Weld in kits
Such Things as the kits never work and you do too musch damage to the car trying to make them work. Also I have heard that the H22 leaves little to no ground clerance. I figure I'm going to go with a B-Series.
for a straight up race car an h series would be totally insane in an ef....almost uncontrollable with all the bolt on's probably.....man, that car would be fun......
place racing makes a bolt in kit.. no welding.. they also make have the axles u need. the wiring.. the cable selector for te cable driven tranny.. look them up and u will find everything you need
to bad place racing website has been under developement for the past 6 yrs.
Do a search, you'll find its not worth it at all, and unless you've done some welding in the past and don't have any problems w/ cutting your car up or the steering then go right ahead
xkellyxveitx
Mar 22, 2011 09:57 AM
Ruby Civic
Jan 3, 2003 05:51 PM
