dohc ZC into '91 Civic upper rad hose problem????
hey guys
used a 1989 Integra upper rad hose (part # 19501-PG6-010) for the dohc ZC in my
'91 Civic Si; I have just noticed that the hose is being pinched at the first bend it
makes coming out of the head (just under the distributor). After removing the hose
and looking at it in plan view, it seems that this first bend as molded into the hose
is much less sharp than required for the fit; thus the hose pinches to about half
of its regular diameter. Has anyone run into this? I will source a 1984 Accord hose
tomorrow,but I have a nasty feeling that this will have the same problem. I beleive
that this is part of the cooling woes I have had with this engine since it was installed
(the other part being the fact that it is a clapped out peice of crap with a jillion miles
on it, that had sat for so many years that it is internally corroded; thanks JK Japanese!).
Any advice?
thanks
greg v
Any advice?
thanks
greg v
I just walked into O'Riellys.. asked for a 84 accord upper radiator hose, paid $12 for it, then went home and chopped about an inch to two inches off the radiator side of the hose. Slid it on and clamped it.. worked perfectly from then on.
B18C5-EH2
Feb 21, 2005 08:11 PM
FourthGenHatch
Apr 27, 2003 03:14 AM
