Mushy Brake after Bleeding... Help..
Old Apr 10, 2003 | 10:14 PM
PiYoImuT's Avatar
Default Mushy Brake after Bleeding... Help..
I did search.. but to no avail..
2 AM and I am just finished bleeding the brakes with new SpeedBleeder..
but now the Pedal is a bit mushy.. will this go away after a day?
how many pumps is necessary when using speedbleeder? it was said 5-7 enough..
(I see no bubbles in the tube)
if not, I'll ask We-Todd team tomorrow to help me with my stupid brakes..
damn.. I should've left the brake alone... *sigh*
Old Apr 10, 2003 | 10:16 PM
Phoenix_ITR's Avatar
Default Re: Mushy Brake after Bleeding... Help.. (PiYoImuT)
the pedal should firm up after a couple of hours. assuming, of course, you didn't push the pedal all the way to the floor while bleeding...
Old Apr 11, 2003 | 04:26 AM
benmasters's Avatar
Default Re: Mushy Brake after Bleeding... Help.. (delinquent)
Your pedal should firm up after bleeding with about 5 pumps off the pedal with the engine started.
Providing you bled them properly. If not you probably got air in there somewhere.
Old Apr 11, 2003 | 05:19 AM
SlapSmak's Avatar
Default Re: Mushy Brake after Bleeding... Help.. (benmasters)
1. Your pedal should firm up as soon as you close the bleed screw.
2. Bleed the brakes with the Engine running, this way the ABS is pressurized.
3. Run the engine with the bumper facing the outside so you dont die from the exhaust.
Old Apr 11, 2003 | 05:56 AM
Cheeseman's Avatar
If it was mushy before the bleeding also, you didn't do a very good bleeding job. Or you introduced air into the system with your bleeding technique.
Cheese~
Old Apr 11, 2003 | 06:16 AM
yoshi234's Avatar
I shoot brides
Default Re: Mushy Brake after Bleeding... Help.. (Cheeseman)
sometimes it helps to tap on the brake lines and caliper while bleeding to l00sen up any air bubbles.
yshi - whose car is ready for the expo but won't be running it there
SurferX's Avatar
Could be a malfunctioning Speed Bleeder. Also did you bleed them with the cap off of the master cylinder? Alot of people say it doesn't matter but I know myself I continuously saw air bubbles coming out of the bleeder when I left the cap off. I put the cap back on and the air bubbles stopped.
Old Apr 11, 2003 | 07:30 AM
ScaleExtric's Avatar
Default Re: Mushy Brake after Bleeding... Help.. (SurferX)
I had the same problem as you did...but after a while it just gradually went away
Old Apr 11, 2003 | 07:58 AM
98R-1144's Avatar
Default Re: Mushy Brake after Bleeding... Help.. (ScaleExtric)
i had the same thing too after i bled for the first time w/speedbleeders.
i just re-bled everything again (w/the car off), making sure not to depress the pedal all the way to the floor.
Mr_Sixx
Suspension & Brakes
Oct 7, 2010 08:14 AM
hamadiscool
Aug 8, 2006 07:30 PM
underage
Aug 9, 2005 05:57 PM
zcivicz
Apr 8, 2005 07:40 PM
Batoutahell
Apr 14, 2003 11:26 AM
