very curious...
Old Apr 10, 2003 | 08:25 PM
T-RexAZ's Avatar
Default very curious...
would the 92-95 civic sohc vtec ex motor drop directly in the 89 hf crx?? with out having to buy aftermarket or different motor mounts?? i know both motors are D series soo it should just drop in yah?? just change axles,ecu,etc. thanks,B
Old Apr 11, 2003 | 06:03 AM
DJ_SaNdOz's Avatar
Default Re: very curious... (T-RexAZ)
it should mount up pretty well- but you'll wanna wire to obd1 so it works right
Old Apr 11, 2003 | 07:54 AM
USDM 4G VTEC's Avatar
do a search
u use ur stock motor mounts,
stock shift linkage
stock dizzy
u gotta use a Si ecu or INtegra 88-91
stock axles
and u can use a better tranny that the HF one.. but it technically works
Old Apr 11, 2003 | 09:13 AM
pokemon's Avatar
Default Re: very curious... (USDM 4G VTEC)
You have to change the driver side mount that is on the block to your HF mount that is in the block cause it won't line up and the motor will sit crooked.
Old Apr 11, 2003 | 12:37 PM
T-RexAZ's Avatar
Default Re: very curious... (pokemon)
hey thanks for the info...so change the driver side mount on the civic motor to my HF one then.
and i can use my stock axles,shift linkage,tranny etc to bolt straight up to the civic motor? thought i would have to change those. well thanks for the info...much love to the ht peeps. peace.B
4NOWJUSTADX
May 18, 2007 10:04 AM
6doorsentra
Sep 3, 2006 12:54 AM
Serdar
Jan 12, 2005 06:21 AM
NismoMugen
Oct 12, 2004 09:01 PM
civicdx1
13
Sep 16, 2004 09:33 PM
