Toda Spec B's on a daily driven GS-R?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">need more compression for those cams to be happy.
go with Skunk Stage1 (my personal fav) or Toda A</TD></TR></TABLE>
all toda a cams & the rest of the toda goodies!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRVtec »</TD></TR><TR><TD CLASS="quote">When daily driving with Toda B its almost manditory you upgrade your timing belt to something stronger!!</TD></TR></TABLE> yea good point..PE or toda belt is a must.
yea.. def upgrade the belt.. and you should be running higher cr.. maybe itr pistons.. what setup do you have? are you running a stock gs-r? if so you should probably do some other things first to get more out of the b's.. the belt is definately a requirement though.. those things lobe like a *****.
i say Toda A's for your gsr if it will be more street than track.
i have A's and i am very happy with them. of course Bs will make more power but more $$$$ too.
what kind of power are you trying to get?
190whp with toda A's that has mad midrange is gotta be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evilteg »</TD></TR><TR><TD CLASS="quote">why do u need a stronger belt for the b's?? which belt would you have to get??</TD></TR></TABLE>
had some problems with belts being broken which can be very very bad.
you can get toda belt or PE belt. most people go with PE due to fact that it is cheaper i believe.
rev210k
Jun 30, 2004 12:24 AM
