I got my new GC springs, which ones go in front???
I just got my new 400/400 spring rates. One is 7" long and the other is 8" long. I guess its my fault for not specifying that I wanted 8" for all four. But anyway, which ones should I put in front? How would a 7" spring behave compared to a 8" of the same rate?
Also they came with different length sleeves. Im guessing the longer sleeve goes with the shorter spring, and the shorter sleeve with the longer spring?
I have my 8" springs in front and 7" in the rear. The fronts rest just even with the upper mount but the rears have about an inch or two of free movement when the car is not on the ground. I haven't had a problem at all though with using the longer ones in front.
The perches are set just like you said though. Longer in back shorter in front.
You can pretty much put them anywhere with the adjustibility in the spring perch and the Koni snap ring.
But, long sleeve + long spring in the back is the general rule. I am running 8" springs front and rear with the long sleeve in the rear.
11psiTurboSI
15
Jul 8, 2004 09:29 PM
VTEConly
35
Jul 22, 2003 08:49 AM
