ST rear sway bar onto a 91 Accord LX?
Actually, i have the cdn EX model, 4 door with rear drums (no sway bar in the rear) which is the same as the LX. what do i need and whats required for making this work? I'm worried about exhaust rubbing issues but i'm sure it could be bent or moved out of the way. thanks all!
You shouldn't need to do anything in regards to your exhaust if it's OEM. As for the S/T sway bar if your trailing arms don't have the holes drilled for the end links you will have to drill them.
I know my 1992 LX although it does not have the OEM sway bar and the cross member is not drilled for it the trailing arms on my year and model are drilled. Hopefully yours will be too.
stallinrawlings
Suspension & Brakes
Jun 17, 2018 01:13 PM
98CIVEX
Sep 12, 2006 01:14 PM
