zc problem
the car is 89 crx dx. Just out in a zc engine and got it to start but i get a map sensor code, and i would start but idle real high. So then I noticed that I was leaking fuel from the regulator. I fixed that, but the car still dies when i give it gas, anywone got any suggestions. At this point im open to anything.
Make sure you didn't confused your MAP sensor plug with your TPS sensor plug they look exactly the same and are close enough to where you could pull that off. If they are in the right spots then you prolly have the map sensor on the wrong vaccuum port. I don't know much about the ZC TB but it should be right on the TB next to the large vaccuum hose. Good luck.
FourthGenHatch
Jun 19, 2003 01:54 PM
