Looking for help picking large turbo, yes its a vw but you guys know your turbos :)
Hello, my name is jay, i'm coming from the vw world and am looking for some turbo help. I've been reading your forums for a while and am very impressed with your turbo knowledge and setups. I have a 1.8t motor that i am looking to get 450-500whp on 104 octane. I am unsure of what turbo to use. THe motor will rev to about 7800-8000 rpms. bore is 81mm stroke is 86.4 i dont know if thats helpful to you guys or not. What would you recommend i should use for a turbo? I am also going to be running stand alone for my engine management. Any help would be greatly appreciated.
thanks
thanks
sorry cant really help, but I wanted to say I love VW. My friends are slowly getting me to like their VW more than my honda
Their site : http://www.exklusivtuning.com/
anyways, bump for you. Reading Maximum Boost by corky bell may help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04s »</TD></TR><TR><TD CLASS="quote">http://www.precisionte.com sc61</TD></TR></TABLE>
That's what I was going to say.
but the SC44 would be the right turbo for 450-500.
The SC44 will support 565hp at the crank (480 or so wheel) with in it's efficiency range.
You don't want to go too big when picking a turbo. Pick a turbo that will support 450-500 with it's sweet spot.
i am going to pick up that book, just figured i'd look to the honda guys cause you seem to be really good at this stuff.
which trim?
SC616370 56 trim Map T350 .63 69 $775.00
SC616376 56 trim Map T350 .63 69 $775.00
SC616369 56 trim Map T04 .63 69 $775.00
SC616376 56 trim Map T04 .63 76 $775.00
which trim?
Billy Tylaska was using a 50 trim T4, with a stage 5 turbine wheel in a .48 a/r housing. made 404 whp off the bottle.
Smarter than you
I remember billy had problems when he installed the 57 trim last year w/ surging. then he went down to a 50 trim. Havn't heard much about him lately but for ur hp goal u r gonna need at least a 60trim or a 60-1. a precision SC61 would be the step above a 60-1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep »</TD></TR><TR><TD CLASS="quote">I remember billy had problems when he installed the 57 trim last year w/ surging. then he went down to a 50 trim. Havn't heard much about him lately but for ur hp goal u r gonna need at least a 60trim or a 60-1. a precision SC61 would be the step above a 60-1. </TD></TR></TABLE>
billy also was using stock managment, so this probably had an effect on the surgin, as our map sensor when it reads over 24psi throws the car into a limp mode.
you will need a new manifold to get rid of the internal wastegate dont forget. I would say a precision sc44 would be good for your hp goals. you would need it to spool quick so get a .48 or .63 rear no matter what. i just pulled my motor from my 1.8t jetta which a friend blew up. the turbo is a joke. it has a 2 inch inlet if that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lugnuts »</TD></TR><TR><TD CLASS="quote">Billy Tylaska was using a 50 trim T4, with a stage 5 turbine wheel in a .48 a/r housing. made 404 whp off the bottle.</TD></TR></TABLE>
Billy is a cool local from here. His good buddy john is using a Precision SC44, which is the 60 trim T04E compressor and a T3 .63AR 76trim(stage 3 wheel) that made I think 430whp. I had posted a video of his car a while back, but I dont know what I did with it.
But like mike said, I would go with the Precision SC44 turbo.
art
art
