Yokohama A032Rs- Can they be used on the street?
Old Jun 24, 2001 | 12:18 PM
Pistonhead's Avatar
New User
Default Yokohama A032Rs- Can they be used on the street?
I was looking on the Tire Rack site and the Yokohama A032Rs seem to be the only competition tire you could stretch to use on the street. Does anyone use them on the street? Are they too dangerous in the rain?
Old Jun 24, 2001 | 12:24 PM
Chris's Avatar
Default Re: Yokohama A032Rs- Can they be used on the street? (ITR-01-269)
Yes. They are noisy though. Dont expect them to last too much longer than 3 months.
I like them alot.
Old Jun 24, 2001 | 12:25 PM
Chris's Avatar
Default Re: Yokohama A032Rs- Can they be used on the street? (Chris)
Oops! I forgot to mention that they are good in the rain....
I think that the BTCC used to use them for rain tires???
Old Jun 24, 2001 | 12:26 PM
ZygSpeed's Avatar
They should last the summer on the street (maybe longer depending on the amount of abuse, errr ... fun),
and any tire is dangerous in the wet when its bald (wear bars).
Old Jun 24, 2001 | 12:28 PM
98-0683's Avatar
New User
true, they are so noise. especially around 70-80 km/h. they are DOT aproved tires, so absolutely can run on street.
Old Jun 24, 2001 | 12:46 PM
Pistonhead's Avatar
New User
Default Re: Yokohama A032Rs- Can they be used on the street? (98-0683)
Do they need to be heat cycled first? I don't do any racing but I heard competition tires need to heat cycled for safety reasons. Does the Tire Rack have them the cheapest? I guess I'll need a 205/50-15 for factory wheels, right?
Old Jun 24, 2001 | 12:52 PM
98-0683's Avatar
New User
just want to ask, why have those tires if u don't do any racing??? sorry no offence.
Old Jun 24, 2001 | 01:02 PM
xMetal's Avatar
If you don't race at all, your money would be MUCH better spent on some high quality high performance summer tires instead of R rated tires. You really don't need that extra grip if you are just driving on the street, and you will save yourself a lot of money if you just get regular street tires. The R tires are going to wear out super fast and street driving will not allow you to get any of the benefits R tires offer.
My $.02
Old Jun 24, 2001 | 01:04 PM
ZygSpeed's Avatar
Default Re: Yokohama A032Rs- Can they be used on the street? (xMetal)
b.s.
it will be a blast going around corners, just watch for pedestrians and cops.
heat cycling is just supposed to make them last a little longer, and probably won't be an issue for a daily driver.
[Modified by zygspeed, 5:06 PM 6/24/2001]
Old Jun 24, 2001 | 01:07 PM
Pistonhead's Avatar
New User
I live in hickville, tennessee, and there are no race tracks for about 150 miles. But since I do live in hickville, there are twisting country backroads that are a blast in a Type R. I want maximum performance and dry grip, noise does not bother me, and $600 every four months isn't too bad. And I love leaving mustangs, camaros, firebirds, corvettes eating my dust through corners...
Old Jun 24, 2001 | 01:11 PM
ZygSpeed's Avatar
I got about two summers out of my last set of 032Rs, and have a fresh set to put on once I get back to Ohio.
They also saved my but from t-boning some lady (because of the good grip/ABS).
By comparison my AVSi suck (though generally they're pretty good tires).
have fun, ed!
[Modified by zygspeed, 5:11 PM 6/24/2001]
Old Jun 24, 2001 | 01:13 PM
Pistonhead's Avatar
New User
What tires do you recommend (for street use) other than RE010s in factory sizes? I wonder if they have Potenza S-03 Pole Positions or Pirelli P-Zeros close to my size. I guess I'll check out the Tire Rack again.
Old Jun 24, 2001 | 01:17 PM
Mike M's Avatar
Founding Member
I will be using the A032R's on the stockers Until I get My Advan A048R in for my Spoons
Other tires that are pretty good in a more street type application Dunlop Sp9000 or maybe the S03's
Old Jun 24, 2001 | 01:24 PM
Superman's Avatar
New User
I'm currently running A032R on my daily driven R and I absolutely love them. I go to the track about once a month. I run 35 front and 32 back cold tire pressure on the street so that the middle part gets most of the wear and save the sides for the track. On the track, I run 32 front and 29 back hot tire pressure. My point is if tire wear and noise are not much of a concern, then A032R is definitely the tires to go with.
Old Jun 24, 2001 | 01:26 PM
ZygSpeed's Avatar
Default Re: Yokohama A032Rs- Can they be used on the street? (Superman)
I'm glad you mentioned "the middle part" ... thought I was just seeing/imagining things!!
Too bad we've only got 6" wide wheels as stockers!
Old Jun 24, 2001 | 01:33 PM
Superman's Avatar
New User
Default Re: Yokohama A032Rs- Can they be used on the street? (zygspeed)
zygspeed, i actually thinks that it looks pretty good with the slight buldge that our narrow rim gives. Basically, the higher the pressure you run, the less contact patch it has. Hence, there's less wear at the sides and more wear in the middle. But one track day would more than compensate for the "uneven wear"
Old Jun 24, 2001 | 01:35 PM
ZygSpeed's Avatar
Cool!
Old Jun 24, 2001 | 01:40 PM
Pistonhead's Avatar
New User
I was just on the Tire Rack site and the Potenza S-03 Pole Positions seem to be the ultimate non-competition maximum performance tire available. Obviously the softer rubber and shallower tread depth of the A032Rs will provide higher ultimate grip, but the S-03 has a 220AA rating on treadwear while providing higher grip than the RE010. The A032Rs, once worn down even more from the 6/32" tread depth, would be kinda tricky in the rain. And where I live, we get precipitation often. That 1.0+ skidpad grip capability is quite alluring, though.
Old Jun 24, 2001 | 02:55 PM
Bob#455's Avatar
No kidding! The wear bars are about to start peeking through... As much as I would like to run these tires on my car, I don't think I could afford to. They are very nice , I just need something that will last me a bit longer on the street.
Old Jun 24, 2001 | 05:13 PM
Dee's Avatar
Dee
Default Re: Yokohama A032Rs- Can they be used on the street? (Bob#497)
you guys would probably die if you saw the tower of tires that I have in my little computer room... Ask Ben Tang about it!!
Old Jun 24, 2001 | 05:28 PM
97GSR's Avatar
i have some for sale if anyone is interested, size 195/60/14.....and are pratically new with about 100 mile on them
cheesebox
14
Dec 12, 2005 03:21 AM
Integ-boy
Apr 10, 2005 07:34 AM
BoM
Sep 2, 2002 08:02 AM
tygsr
12
Jul 17, 2002 05:59 AM
ActiveAero
Oct 29, 2001 04:31 AM
