Oil leak from seals between cams and cam gears
when i pop my hood i see sprayed oil over the bottom it and is coming from the cam gears because the valve cover is cut and they are exposed. How much is the seal that goes between the cams and the cam gears. Thats the only possibility that the oil is coming from, right?
TealEG!
Aug 5, 2008 08:10 PM
nexgen91
Jul 31, 2007 07:08 AM
