Rear Disc conversion parts list????
Old Apr 10, 2003 | 10:55 AM
AK94GSR's Avatar
Default Rear Disc conversion parts list????
I would like to put some disc brakes on the back of my friends civic ex.
what is the parts that u will need to do this conversion
and if anyone has photos that would be good too
Old Apr 10, 2003 | 10:57 AM
EL Vap133's Avatar
Default Re: Rear Disc conversion parts list???? (AK94GSR)
You mean his EX didn't come with rear disks? What year Civic does he have?
Old Apr 10, 2003 | 10:58 AM
Spade's Avatar
Default Re: Rear Disc conversion parts list???? (Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You mean his EX didn't come with rear disks? What year Civic does he have? </TD></TR></TABLE>
The only EX's that had rear disks were the Sedan's with ABS...not that common at all.
Old Apr 10, 2003 | 11:00 AM
DualKnuttz's Avatar
Banned
The parts that you will need are:
1. Rear disk brake assembly with ebrake cable attached
2. brake lines for disk brakes. similar to the ones used for the front brakes
3. Brake fluid
Old Apr 10, 2003 | 11:32 AM
warwagon's Avatar
Default Re: Rear Disc conversion parts list???? (Spade)
There a two ex coupes here locally with rear disc, they are all stock except one has some borbets (that how I noticed the disc) and my cousin owned one that had rear disc, coincidence or not they were both white cars don't know years these are the only 92-95's I had seen with them. As for the brake swap you just need the rear hub assembly= hub, rotor, caliper, lines, and e-brake cables.
Old Apr 10, 2003 | 11:40 AM
kommon_sense's Avatar
Default Re: Rear Disc conversion parts list???? (warwagon)
some 92-95 ex's with ABS came with rear discs.
I have a 98ex w/rear discs, but I put them on myself. Anyways, just follow the howto at http://www.hazone.com . I used them to do my install and didn't have any problems.
Old Apr 10, 2003 | 11:50 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">
The only EX's that had rear disks were the Sedan's with ABS...not that common at all.</TD></TR></TABLE>
My old roommate's 94 Civic (dunno if it was a Canadian model registered in CA or what) had rear disc brakes and ABS. But back to the original subject, just get the rear trailing arms and ebake cables and the rest is pretty much interchangeable - just use the 94+ Integra parts. Now on an EK, I'm figuring out what's the same and what's different for my "new" car
jdm94accord
May 4, 2006 09:21 AM
squirrelrun
Nov 17, 2005 06:19 PM
HANABLE
Apr 8, 2004 11:08 AM
