Y8 Head gasket on an A6?
Old Apr 10, 2003 | 07:52 AM
hondaless's Avatar
Default Y8 Head gasket on an A6?
Can I run an Y8 headgasket on a D16a6 Block with 11:1 compression pistons on a stock head? What compression would it give me? Also would I be able to get a more aggressive camshaft and still be safe? Thanks for the help.
Old Apr 10, 2003 | 08:32 AM
Outsane's Avatar
Default Re: Y8 Head gasket on an A6? (evilcrx)
yeah you can run the y8 gasket..it will bump up the compression a tiny bit..
there is a link somewhere that does the calculation for you.. I don't have it here at home... its on my computer at work... Talk to the people you would get the cam from about clearance issues, it depends on what rods and pistons your using.
Old Apr 10, 2003 | 09:27 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
the y8 HG will bump compression about 0.2 to 0.4 depending on the combination.
11:1 compression pistons...does that mean stock block, head (no mill...valve lapping), stock HG???
need to know more about the pistons...like:
Piston-to-Deck Clearance (in)
Dome/Dish Volume (cc)
here are some cam choices:
https://honda-tech.com/zerothread?id=427814
Joey Mitchell
Nov 19, 2018 11:53 AM
jdmhonda123
Dec 1, 2010 10:28 PM
pip9
Jul 12, 2004 05:10 PM
