STR Cam Gears?
Old Apr 10, 2003 | 06:12 AM
jinxman's Avatar
Default STR Cam Gears?
Anyone have any experience with these? I'm debating on getting them but i have yet to find any documentation on what kind of performance gains they offer or even if they are a good product. Help?
Old Apr 10, 2003 | 06:22 AM
pzpos360's Avatar
Default Re: STR Cam Gears? (jinxman)
I have those cam gears but have not yet put them on my car. Got'em from inline four, I do not have them in front of me now but I believe they have five bolts and seem to be pretty descent in construction, but I am no expert by far. Check strpower.com
Old Apr 10, 2003 | 08:05 AM
jinxman's Avatar
I checked the site but it doesn't have the type of information I'm looking for. I also read the press release and they seem to be made well, but I would like to find someone with some experience with them, or to at least find out how good STR products really are.
Old Apr 28, 2003 | 08:20 AM
jdhealy's Avatar
Default Re: (jinxman)
seems like i have seen a lot of them that slip and are striped out
Old Apr 28, 2003 | 12:21 PM
Captn. Save A Hoe's Avatar
Default Re: (jdhealy)
JD, your refering to the OLD gears that were made by a well known sleeving company.. All of STR's new products are made in house, and to this day i havent heard of any of the new "bronze" gears having problems..But thats just me
chris
Old Apr 28, 2003 | 01:33 PM
pzpos360's Avatar
Default Re: (Pr1ck of H-T)
I haven't installed mine yet, are you sure there is no problem with these gears. I have no interest in f'ing my engine up. Does anyone know a contact number for STR
Old Apr 28, 2003 | 02:55 PM
jdhealy's Avatar
Default Re: (pzpos360)
ya i jsut checked out thoes new ones if i had the money to get them i would look a lot better then the old ones
Old Apr 28, 2003 | 10:35 PM
BDL IND's Avatar
The gears are a new design and are set to very strict standards. They are not actually cut on a cnc machine like several competitors gears which happen to be done incorrectly(How are old gears 3 spoke, 3 bolt ones, were done in the past). We now actually use the correct cutting tooth which is set up by the RMA(they make the timing belts). and done on a true gear cutting machine.
If you actually look on Inline four's website it talks about how Spoon came down and were checking out the other gears and quoted how if their gear was unavaiable they would run the STR gears due to it's construction.
I was pretty happy with that quote.
We have done alot of redesigning of the entire product line here and are really happy with the results.
All the products have been tested while we were out of commision for some time. Please feel free to give us a call if you have any questions. 909.272.2150
Old Apr 30, 2003 | 09:10 AM
ImportechPerformance's Avatar
Default Re: STR Cam Gears? (STR)
str how much your b-series cam gears run? ive looked at your dealers and only found SOHC gears...
Old Apr 30, 2003 | 11:22 AM
ProStock MaMa's Avatar
Default Re: STR Cam Gears? (TheRedSkoolingBus)
call STR
909-272-2150
or go to there website and email them
http://www.strpower.com
Old Apr 30, 2003 | 11:43 AM
Teen Heartthrob's Avatar
Default Re: STR Cam Gears? (AllMotorMama)
do they make cam gears for the h22a?
Old Apr 30, 2003 | 12:01 PM
2point6's Avatar
Default Re: STR Cam Gears? (Teen Heartthrob)
I have them on my engine (h22a)
Old Apr 30, 2003 | 12:10 PM
juicedh22's Avatar
Default Re: STR Cam Gears? (2point6)
The shop that built my motor, as well as some other very well built motors, they highly recommend, and use the STR cam gears in all there builds. GOOD stuff
...now the STR throttlebody on the other hand.... caused me nothing but problems
Old Apr 30, 2003 | 12:11 PM
silver97prelude's Avatar
how much do these run?
Old Apr 30, 2003 | 12:44 PM
Default Re: STR Cam Gears? (silver97prelude)
where is a good place to buy these from? (im assuming they are around the price of skunk2 cam gears..?)
Old Apr 30, 2003 | 01:31 PM
juicedh22's Avatar
Dynamic sells them, they are in cali
Old Apr 30, 2003 | 02:01 PM
pzpos360's Avatar
Hey(since you have these installed already) what are the torque specs for the adjustment bolts, also, how many degrees is each white hash mark? I have these in my hand right now and I am having difficulties figuring out how these line up( in regards to how to line up the inner etching mark and the outer white hash marks?) Any help would be appreciated
Old Apr 30, 2003 | 02:06 PM
pzpos360's Avatar
http://www.inlinefour.com
Old Apr 30, 2003 | 03:02 PM
Default Re: STR Cam Gears? (juicedh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicedh22 &raquo;</TD></TR><TR><TD CLASS="quote">The shop that built my motor, as well as some other very well built motors, they highly recommend, and use the STR cam gears in all there builds. GOOD stuff
...now the STR throttlebody on the other hand.... caused me nothing but problems </TD></TR></TABLE>
Contact STR (909) 272-2160.. They will try and help you out to the best of there abilities... to a bunch of good guys and dope *** products..
chris
Old May 1, 2003 | 07:40 AM
2point6's Avatar
Default Re: STR Cam Gears? (pzpos360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pzpos360 &raquo;</TD></TR><TR><TD CLASS="quote">Hey(since you have these installed already) what are the torque specs for the adjustment bolts, also, how many degrees is each white hash mark? I have these in my hand right now and I am having difficulties figuring out how these line up( in regards to how to line up the inner etching mark and the outer white hash marks?) Any help would be appreciated </TD></TR></TABLE>
The idea is to line up the inner marks with the outer ring. For example: if you want a 2 degree retard/advance on your cam, you count the mark on the inner ring (to the second mark) then you count the outer ring (to the second mark) line up the 2 marks.
**Each mark when lined up is 2 degrees crank.
I have the torque specs at home. If no-one post them, I will post them later.
Old May 1, 2003 | 09:55 AM
juicedh22's Avatar
Default Re: STR Cam Gears? (Pr1ck of H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr1ck of H-T &raquo;</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
nah, I already got rid of it. I mean, the STR tb looked great, and im sure it would perform well for the right application, but it just wasnt the right TB for my setup. But I definately think STR has some GREAT quality parts...
Old May 5, 2003 | 06:52 AM
Kev95lx's Avatar
I'm just curious, does anyone know how these compare to the Unorthodox Racing Ts cam gears?!
Old May 10, 2003 | 12:01 PM
Kutsuju_SLeePER's Avatar
Default Re: STR Cam Gears? (Kev95lx)
My friend has the STR cam gears, been in for a week and is gonna go back to his old AEM gears. He has a B16. Im gonna take advantage and buy them off his dumb *** Dirt cheap. I have a 96 GSR, they should fit the B18 as well right? I know everythign is pretty much compatible with b series engines.
Old May 15, 2003 | 04:58 AM
Kev95lx's Avatar
I called up Scott @ STR, he was able to point me to a shop in FL that had them since the CDN distributor was sold out..I placed my order and 24hrs later I had a set of the Pro Gears at my house. Great product and great fast service.
Thanks again to Scott & Darrin/Steve from Pacific Performance.
Old May 15, 2003 | 11:40 AM
slowdx's Avatar
Default Re: STR Cam Gears? (Kutsuju_SLeePER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">My friend has the STR cam gears, been in for a week and is gonna go back to his old AEM gears. He has a B16. Im gonna take advantage and buy them off his dumb *** Dirt cheap. I have a 96 GSR, they should fit the B18 as well right? I know everythign is pretty much compatible with b series engines. </TD></TR></TABLE>
Why is he going back to the AEM,
Im the high bidder on a set of them new bronze gen STR gears. Ends in 1 59 minutes or something on ebay YEY.lol 81 bucks. plus shipping.
