Parting out 90 Integra - LOTS of upgrades - Also 2nd gen b16a, b20, exhaust, EG civic parts...
Old Apr 10, 2003 | 01:25 AM
Tr0LL's Avatar
Default Parting out 90 Integra - Brake Conversions, b20 stuff, EG Civic parts, Springs, Intake Manifold, TB
LAST CHANCE as I am junking the shell VERY soon. All reasonable offers on the shell parts will be accepted as long as it's worth my time removing the part. If you are local and can come take it off yourself, it'll be even cheaper. ANY OFFER will be considered on these parts (such as the 100% working sunroof)
All prices are OBO and do NOT include shipping. Pictures can be taken for anything upon request (Here are some that I have taken already http://home.socal.rr.com/tr0ll/FS/ ). I am located in Southern California. I am also paypal verified (3% extra for paypal) and have lots of feedback on ebay. Pick up welcomed... Please email me at tr0ll@innocent.com (the 0 is a zero).
Parts from my 1990 Acura Integra, should fit all 90-93 DAs
*Parting out a 1990 Integra GS
Non-vtec/OBD-0 B16a Throttle Body with TPS - $75
1990 Integra Axles (Driver and Passenger) - $125
1990 Integra Shift Linkage - $125
DA 90-93 Integra Stock Front Sway bar with Polyurethane bushings - $50
Two Color (Blue/Green) Indiglo Guages for DA 90 Integra GS - $20
White Vinyl LS Seats - Front and Back - Driver seat is somewhat dirty but probably cleanable. The rest are pretty good. I have had them for about 2 years. Still look nice to me. - $350
Red Magnacore Ignition Wires - about 2-3 years old - still in great condition - They run about $70 new - $30
Autometer Phantom A/F Guage /w Carbon fiber POD - $60
1st Gen B16a Exhaust Manifold - (got like 3 of these) - $30
Andy's Autosport Bonzai Front Bumper - Bunch of cracks that have been "fixed" by me and some that have not. If you get it refiberglassed and fixed it would still look nice - $50
Andy's Autosport Combat Rear Bumper - Was hit in the left rear - needs a lot of work/fiberglass to be fixed. I think it can probably be fixed. It's just fiberglass... Dirt Cheap - $20
(2) Andy's Autosport Combat Side Skirts - decent condition - $50
Clear/Red Taillights - These are really clear tail lights but I painted the bottom red. The paint is coming off though. Put these in some paint stripper and you got yourself some clear tail lights. There is a slight crack on the left one and it doesn't fit all that well (small gap on the left side) - $50
90-93 Integra DRIVER Door /w Power Windows and Door Panel - $90
Fuel Rail with Injectors - Make offer
Front and Rear Lower Control Arms - $100
Parts that I got with or for my new 93 Civic......
Neuspeed Race Springs - This will actually fit all 92-95 Civics and all 94+ Integras. Actually only the 2 rears are Neuspeed Race (Yellow), but the 2 fronts are some unknown brand. They are a light neon colored green, however they lower the car about the same as the real Neuspeed race springs. Springs are uncut and lower the car approximately TO a 1 finger gap in the rear, and a 0 finger gap in the front. Very nice looking drop (I have pictures of the drop on my Civic) - $75
B-series OBD-2 NON-VTEC Distributor (from my JDM B20B)- should work with any obd-2 non-vtec car or maybe vtec if you modify a bit (cut off a leg) - less than 45k miles on it - $125
B16a3 Bare Intake Manifold - NO sensors - $75
JDM B20b Bare Intake Manifold - low rise version (looks like an LS one) - better than LS manifold because of the bigger ports - $75
JDM B20b/2ND gen B16a Throttle Body - No sensors/TPS - $75
Automatic B-series Flywheel (came off the JDM B20b) - $20
AEM Cold Air Intake for 92-95 Civic. Will TRADE for Any aftermarket intake/filter + $100.
B16a3 Stock Clutch Disc and Pressure Plate and pilot bearing - I pulled it off the b16a3 which had about 65k miles on it. - $40
95 Del Sol Front Brake Conversion (Comes complete with knuckles, 10.4" rotors, pads, calipers) - Straight bolt on for EGs, good upgrade from the stock 9.X rotors, needs new wheel bearings - $50 (VERY heavy, prefer pickup)
WTB or Trade for:
ITR or GSR Steering rack with subframe (or just the rack is ok too)
A/C Mount that will fit my b20 in my 93 Civic. Basically the LEFT/DRIVER front torque mount.
SOLD:
Y1 Cable Tranny from First Gen B16a - no more than 55k miles - slightly grinds in 4th gear if you shift into it too fast - SOLD....
USED Exedy Racing Clutch (Organic Street Disc) with both bearings - Used for about 10k miles/1 year - Part # 08-804 - SOLD....
12 lb Lightened B-series Stock Flywheel (Was just shaved off the back) - Probably needs to be resurfaced - SOLD....
DEI Viper 500+ Alarm /w the shock sensor, the brain, the wiring harness, 2 remotes, LED, valet button, Semi-working Horn) - Works great, I just upgraded - SOLD
DA 90-93 Integra Suspension Techniques Rear Sway Bar with bushings - SOLD
Rear Door Handles from a 4 door (No Key Holes) - These are for you that want to replace your front door handles with rear ones so that there is no key hole. Looks much nicer - These are already modified as they were on my 2dr Integra in the front - SOLD
Red DOHC VTEC Valve Cover - Not sure if it's the real Type R one, but it does look stock (you know, the wrinkled finish) - SOLD
1993 Civic SI VTEC OBD-1 P28 Stock ECU - SOLD
Greddy SP Cat-Back Exhaust - was on a 94 Integra 4 door - Muffler was painted black (1 light layer) and Tip was cut off however I still have the tip - SOLD
(4) 16" TE-37 - WHITE, NO tires, +42 offset, 16x7", USED condition, has a few curbs, scratches, but wheels are still good to run on, not heavily damaged or anything. Still perfect circles. Still have the stickers on them too. Will take individual pictures of all of them soon for interested parties - SOLD
1st Gen B16a Head - COMPLETE - comes with everything in the head (VALVE COVER - Painted White, cams, valves, cam gears, all sensors such as vtec solenoid, everything IN the head). No distributor, no intake manifold, no exhaust manifold)- Head is still on the shortblock. about 55k miles on it - SOLD
2nd Gen B16a3 Head - COMPLETE - comes with everything in the head (VALVE COVER, cams, valves, cam gears, all sensors such as vtec solenoid, everything IN the head). No distributor, no intake manifold, no exhaust manifold)- Did a compression test before pulling it and was all above 205 and 210. Means the valves are not bent. Head is still on the shortblock. VERY clean (intake and exhaust ports) - about 65k miles on it - SOLD
One Piece Headlights for 90-93 DA Integra. Does not come with original H4H bulbs. Will include the H4, the fog light and corner bulbs. Bottom bracket has been cut for easy installation. Still white. - SOLD
1st Gen B16a Shortblock - COMPLETE - comes with everything from oil pan to rings (pistons, rings, crank, crank pulley, oil pan, etc) - about 55k miles on it - SOLD
(4) Tokico Illumina Shocks for DA 90-93 Integra (BU2851, BU2852, BU2863) - Used for about 3 years so roughly 30k miles on them - I still have the receipts if they help for warranty. They still seem pretty stiff to me. (I used to use them on settings 3/4 on H&R Sport Springs) - SOLD
Lynx 2000 Remote Start/ 2-way Pager Alarm - Great range, awesome alarm, but no mute on remote, so I need to get one with a mute - SOLD
H&R Sport Springs for DA 90-93 Integra - SOLD
OBD-1 PR4 Unchipped ECU (Same as P74/P75 from 94-95 Integra LS) - SOLD
Integra Type R Intake Manifold - bare - SOLD
B&M FPR already installed on my fuel regulator and the guage - SOLD
Greddy Power Extreme Muffler (I think this was from an Integra, but the hangers have been cut to fit my custom piping anyway) - has a scrape and a dent at the bottom, shouldn't affect performance/sound at all - SOLD
PR3 1st Gen B16a OBD-0/Non-OBD Unchipped ECU - SOLD
BRAND NEW UNOPENED Universal 1 Wire O2 (Oxygen) Sensors - http://www.automedicsupply.com/pictures/250-21000_.jpg - SOLD
2nd Gen B16a3 Shortblock - COMPLETE - comes with everything in the block(pistons, rings, crank, crank pulley FROM B20, oil pan, all sensors such as knock sensor, everything). No exhaust manifold - Did a compression test before pulling it and was all above 205 and 210. Means the rings/pistons are good - However, it has rod knock I suspect. Very cheap to fix if you know how - Motor was still running, but I never ran it more than 3 minutes or .00001 mile (from drive way into garage) - Bought the car like that and pulled the motor right away - about 65k miles on it - SOLD
1990 Integra Intermediate Shaft - SOLD
90-93 Integra Fenders - SOLD
90-93 Integra Hood - $70 - SOLD
90-93 Integra Stock Springs - $30 - SOLD
90-93 Integra Custom Cold Air Intake (3" Piping) /w filter - $75 - SOLD
(4) Stock shocks. Not sure if they are blown. How do I tell? Anyway only want $20 - SOLD
B-series OBD-0 VTEC Distributor - from a 1st Gen B16a - will work with any obd-0 vtec car or even non-vtec if you modify a bit - about 55k miles on it - SOLD
Complete Front Disc Brakes - Everything - Knuckles, Upper control arms, rotors, calipers, brake lines, AEM brake pads, and whatever else I forgot to add - SOLD
Complete Rear Disc Brakes - Everything - Trailing arms, knuckles, rotors, calipers, brake lines, Axxis brake pads, and whatever else I forgot to add - SOLD
90-93 Integra Power Mirrors - SOLD
Stock 92-95 Civic Hatchback Hood - Not painted - whitish/grey - SOLD
Modified by Tr0LL at 2:07 AM 2/3/2004
Old Apr 10, 2003 | 08:04 AM
zilverz's Avatar
Default Re: Parting out 90 Integra - LOTS of upgrades - Also 2nd gen b16a, b20, exhaust, EG civic parts... (
sent pm
Old Apr 10, 2003 | 08:40 AM
Audipwr1's Avatar
400shipped for gen2 head
or 550 shipped if you have dizzy, TB,intake manifold and injectors
Old Apr 10, 2003 | 08:45 AM
djsbon's Avatar
pics of 1st and 2nd gen b16a head?
pics of b16a shortblock?
edit: pics of type r intake and 1st gen y1 tranny.
sbon@comcast.net
Modified by djsbon at 6:16 PM 4/10/2003
Old Apr 10, 2003 | 12:42 PM
Audipwr1's Avatar
post the links when they go up on ebay
thanks
Old Apr 14, 2003 | 07:13 AM
djsbon's Avatar
the block that the second generation head is on... what are you doing with that? any chance you would want to sell as nearly complete engine?
Old Apr 14, 2003 | 12:30 PM
EL Vap133's Avatar
Default Re: (Tr0LL)
Where are you located at?
Old Apr 14, 2003 | 09:39 PM
SLOW4drINTEG's Avatar
pm'ed and email'ed you
Old Apr 16, 2003 | 06:37 AM
djsbon's Avatar
i can get a brand new (better condition than your's) short block from my friend in alabama for circa $400.
Old Apr 16, 2003 | 06:44 PM
zilverz's Avatar
you still proud of those 3 year old iLLuminas ?
Old Apr 16, 2003 | 10:14 PM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tr0LL &raquo;</TD></TR><TR><TD CLASS="quote">proud? huh? I don't get it.... If you are asking if I still have them, yes I do...</TD></TR></TABLE>
meaning do you still want a fortune for them ?
Old Apr 17, 2003 | 06:43 AM
zilverz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tr0LL &raquo;</TD></TR><TR><TD CLASS="quote">oh.... naw, i don't want to sell for $200 shipped.. after paypal and shipping i'll get like $150... They are working perfectly for me, and it's not like I was riding on race springs.... I was riding on sport springs.... Plus they have a life time warranty.... I still have the receipts...</TD></TR></TABLE>
for something that is 400 brand new ... welcome to the real world .. thats what they are worth ... maybe you can get the 200 local and save on the shipping ...
btw
paypal is like $6 on $200
and shipping shouldnt exceed $20
so its more like youd clear $175
Old Apr 27, 2003 | 08:48 AM
RickChew's Avatar
Default Re: Parting out 90 Integra - Also b16a motors, b20 stuff, muffler, EG civic parts, suspension, swaps
Do you have the brakes from the teg? Thanks! Rick
Old May 2, 2003 | 07:03 PM
HybriDNA's Avatar
Default Re: Parting out 90 Integra - Brake Conversions, b16a shortblocks, b20 stuff, muffler, EG Civic parts
Hey Jonathan. I got the package today as planned and very happy. Thanks you for your fast service and shipping. Everything done as said. for you!!
Old May 4, 2003 | 08:20 AM
RickChew's Avatar
Hey man, I inquired a while ago about the brakes, do you have any idea on shipping? Thanks! Rick
Old May 6, 2003 | 09:39 AM
nsxblueteg's Avatar
I might be interested in the front bumper do you have a pic of it on the car?? and how much shipped to south bend in 46619
Old May 6, 2003 | 12:03 PM
RickChew's Avatar
Lemme find out if the front brakes will work, if so I will take them! Thanks! Rick
Old May 6, 2003 | 12:10 PM
JCracer723's Avatar
Default Re: Parting out 90 Integra - Brake Conversions, b16a shortblock, b20 stuff, muffler, EG Civic parts
check IM
Old May 9, 2003 | 11:26 AM
CrxSi707's Avatar
Bump for a good seller..... product recieved as stated and in a timely matter.
Old May 21, 2003 | 04:28 PM
JCracer723's Avatar
Default Re: Parting out 90 Integra - Brake Conversions, b16a shortblock, b20 stuff, EG Civic parts (Tr0LL)
check email
Old May 25, 2003 | 04:23 AM
92SiB18C1's Avatar
Default Re: Parting out 90 Integra - Brake Conversions, b16a shortblock, b20 stuff, EG Civic parts (JCracer7
Can I buy just the rear springs?
Old Jun 23, 2003 | 11:53 PM
ninjaMONKEY
Guest
Posts: n/a
Default FUEL GAUGE??
do you still have the fuel level sensor (in-tank)?
still got the rear brake lines?
located in Irvine
pm sent
fuel level sensor is #15 in pic below:
Modified by ninjaMONKEY at 8:33 PM 6/30/2003
Old Jun 30, 2003 | 07:02 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: FUEL GAUGE?? (ninjaMONKEY)
bump
Old Feb 3, 2004 | 01:08 AM
Tr0LL's Avatar
Default BUMP!
Last bump before I junk the shell... All previous replies of mine were deleted to clean up...
Old Feb 5, 2004 | 08:15 AM
c1civic's Avatar
i got a gsr subframe and sterring rack , mak an offer shipped, im in ohio
SpoonREVS
Sep 14, 2005 01:27 AM
