99 Gsr suspension..... on 92-95 civic
hi i found someone selling the whole complete front suspension from a 99 gsr ... will it bolt right on to my 92 civic si? if so can someone explain the procedures or have any info or tips... is this all the right stuff or is there missing things i need to get:
"99 Gsr complete front suspension includes shock,spring,hub, knuckle,upper arm, brake calipers"
u should really get a Helms or some kind of manual even a chilton or haynes from pep boys, they show you diagrams with torque specs.
the easy way is uninstall the old suspension and install the new suspension the same way. and torque to spec...then go get an alignment.
