Camber kit question for 96-00 Civic
Ok I bought a camber kit from someone on H-T and they said it will work on my 98 Civic. Well my other friend told me it won't. He says I need the a-arm one. This is the one I have:
Will it work on my car? I have a 98 Civic. Please help!
doesn't look like 3573 is for the 96-00 Civic: http://www.ingallseng.com/cars/honda.html
those look like 92-95 civic camber kits because the 92-95 civic anchor bolts in a vertical position next to the shock tower and can be adjusted inwards or outwards for positive or negative camber. but, the 96-98 civics' anchor bolts, bolt in a horizontal position along the shock tower as well.
therefore, if it mounts in a horizontal position and the camber adjustments on the ingalls are on the bottom, the camber can not be adjusted. and from what i can recall, the 96-00 civics camber kits are the upper control arm replacements.
hth
hth
