???? JDM itr--USDM itr cams ????
is there any difference in the specs for these to cams.....i know that the stock hp on the JDM is more that on USDM so, was just wondering if anyone knew if there is a differnece in the cams duration, etc.
thanks in advance guys....
I have the JDM itr cams myself in my b16, and from what I know the JDM cams have a little more lift and duration than the USDM cams. It is almost always the case (except when the part numbers are the same... duh) that the JDM part will be marginally better than that used on USDM models. However, particularly if you have a b16, the civic type r cams (actually, only the intake cam... the exhaust cam is the same) have a couple degrees more rotation and lift than the itr cams and are reported to produce a few more horses.
thanks for the reply.....yeah but i found a used pair of USDM ITR cams I/E for 300....so was just wondering like to do things right the first time,even though it may cost more sometimes, yeah i know about the CTR int cam being better....
92 Civic 4 dr....B18C...spoon cam gears....I/H/E....9.55 1/8 ET.....on street tires.....cams hopefully here i come......
keep the comments coming
mugenracer
Jul 24, 2002 03:15 PM
