Which street cams would you recommend???
Old Apr 9, 2003 | 08:25 PM
JDM EG2's Avatar
Default Which street cams would you recommend???
I am debating on getting either a set of CTR or skunk2 stage 1 cams. I don't plan on changing the valve springs any time soon. Which are best for power output and everyday drive ability? See my sig for current mods for the 92 vx if that helps you any in what might be best.
Old Apr 9, 2003 | 08:32 PM
romeo619romeo's Avatar
Default Re: Which street cams would you recommend??? (TurboB16Coupe)
ctr.. cant beat OEM.. still good for stock valve springs if you dont move the rev limiter
Old Apr 9, 2003 | 08:49 PM
VTECorona's Avatar
Default Re: Which street cams would you recommend??? (romeo619romeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">ctr.. cant beat OEM.. still good for stock valve springs if you dont move the rev limiter</TD></TR></TABLE>
[sarcasm]skunk2 stage1's can beat OEM [/sarcasm]
I suppose the ctr's would be a safer route but your gains won't be as nice as having skunk2 stage1's.
Old Apr 9, 2003 | 08:50 PM
B2FiNiTY's Avatar
ITR/CTR
Old Apr 9, 2003 | 08:57 PM
tilt's Avatar
Default Re: Which street cams would you recommend??? (B2FiNiTY)
I'm in the same boat, cant decide on itr/ctr or skunk2 stage1 cams. How much more hp does the stage1's make with stock revlimit? and how is the usable midrange hp/torque? tia
Old Apr 9, 2003 | 08:59 PM
Ketone's Avatar
I bet the mid-range would be a little bit better with the CTR cams and the Skunk 2's would be a lot better up top. Personally, I would get the Skunk 2's because I think they are better just my opinion.
Old Apr 9, 2003 | 09:02 PM
VTECorona's Avatar
Default Re: Which street cams would you recommend??? (tilt)
skunk2 stage I's made 12.6 more HP than ITR cams. dyno proven
http://www.skunk2.com/engine/camshaft_dyno.htm
Kelvin96GSR's Avatar
25 Year Member
Default Re: Which street cams would you recommend??? (Ketone)
if you're trying to decide between the 2 I'd get OEM CTR/ITR.
I ended up choosing Jun3, Skunk 2 stage 2 are the same thing I believe
Old Apr 9, 2003 | 09:36 PM
neo1z's Avatar
Default Re: Which street cams would you recommend??? (Kelvin96GSR)
&lt;------------------ Skunk2 Stage 1 junkie
MOE@Hyper16Valve
Feb 8, 2009 10:15 AM
bl1tzk1213g
Jan 29, 2008 06:56 AM
7rrivera7
Sep 25, 2006 09:03 AM
7rrivera7
Sep 25, 2006 08:35 AM
Fresno_NSX
Mar 28, 2005 01:24 PM
