zc ecu
It will hook up but run a little rich and your redline will be 6800. If you go with a PM7, the A/F ratio will be exact and redline will be 7200. Check eBay for the ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF »</TD></TR><TR><TD CLASS="quote">It will hook up but run a little rich and your redline will be 6800. If you go with a PM7, the A/F ratio will be exact and redline will be 7200. Check eBay for the ECU.</TD></TR></TABLE>
actually, the integra PG7 has fuel cut-off at 7500rpm and having tried PM6, PM7 & PG7 on the ZC, we get better performance with the PG7 - as for running rich, if your O2 sensor is doing it's job, it will adjust the A/F ratio - hasn't been a problem for us.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">
actually, the integra PG7 has fuel cut-off at 7500rpm.... </TD></TR></TABLE>
Correct, but if you read my post I said redline was 6800...for the TEG..
Modified by 1990hondaHF at 1:17 PM 4/10/2003
the 6800 is the redline on 90-93 PR4 tegs ECU when warm. PG7 (88-89 teg) redline is 7200 when warm and 6800 when cold...PM7 is the ZC ECU which is 7500 when warm
90 Si Hatch
17
Feb 17, 2005 08:52 AM
junkyardRx
Apr 8, 2004 09:25 PM
South Bay Surfer
Feb 29, 2004 12:10 PM
