leakdown test
Old Apr 9, 2003 | 05:54 PM
S13 slide's Avatar
Default leakdown test
how can you tell if its the rings, valve seals, headgasket ect from a leakdown tester? thanks
Old Apr 9, 2003 | 08:26 PM
psi420's Avatar
Default Re: leakdown test (S13 slide)
Based on where you hear the air escaping from.
Rings = Oil Dipstick
Valves, Seals = Valve Cover, Intake & Exhaust
Headgasket = Oil Dipstick, Bubbles in Radiator
Any questions?
Old Apr 10, 2003 | 10:03 AM
S13 slide's Avatar
Default Re: leakdown test (psi420)
ohh, so you just listen for the air leaking? then whats the gauges for? thanks
Old Apr 10, 2003 | 10:16 AM
psi420's Avatar
Yes,
One gauge tells you you have supplied 100psi to the source.
The other gauge tells you how much air is escaping.
So if the second gauge reads 85psi you know you have 15% leakage somewhere, now you listen for air.
dE.fUsEd
Apr 3, 2012 08:58 AM
kornkid21792
Feb 20, 2010 09:18 AM
mtownsi
13
Feb 3, 2008 05:40 PM
rice92
Jul 6, 2004 07:57 PM
mojoGSR92
Jan 29, 2003 09:27 AM
