rear disks
really not for shure on this and I've never really got a strait awnser on it. from what I understand a 91 interga rear disk will wolt into a 88 crx...other wise what is need to convert a 88 crx to rear breaks thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd1fidy »</TD></TR><TR><TD CLASS="quote">really not for shure on this and I've never really got a strait awnser on it. from what I understand a 91 interga rear disk will wolt into a 88 crx...other wise what is need to convert a 88 crx to rear breaks thanks for the help</TD></TR></TABLE>
crx-si (with rear disc) e-brake cables. YO!
u can get rear disc from 90-91 CRX Si or 90-93 integra
this pic tells u in short terms all u gotta do....
it takes 5 bolts... u have to use the ebrake cable from the car u get the rear disc from... and u gotta use ur stock compensator arm... other than that its a bolt on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzz Kill »</TD></TR><TR><TD CLASS="quote">Your '88 rear shocks will have to be replaced with 89+</TD></TR></TABLE>
yup hes right
oh while u at it , get the rear sway bar from the donator car so u will get better handling.....
yup hes right
Ive done the rear trailing arm swap and it's kind of a bitch, and it's not worth it esp. now since if you just go to fastbrakes they have a kit to convert the drums over to disc. disc are heavier and wont stop you any better than drums. disc look cooler I agree, but I will not do that swap again. the downside to drums is that you must adjust them more often to keep them working tip-top, but they do work just as good as discs on our light-weight cars and you can adjust the parking brake like crazy, 3 clics your done
Coletrain
Jan 31, 2005 04:15 AM
