Boring out the B20
Old Apr 9, 2003 | 03:40 PM
lazy bum shaughn's Avatar
Default Boring out the B20
Well if you plan on doing a B20/VTEC setup, and using JE pistons, I hear they only make 84 and 85mm pistons. So will it be safe boring and honing a B20 block(I know they have weak sleeves) to 85mm?
Thanks.
Old Apr 9, 2003 | 03:51 PM
warwagon's Avatar
Default Re: Boring out the B20 (lazy bum shaughn)
i have 84.5 arias pistons, prolly about the same price as je's unless your set on je's
Old Apr 9, 2003 | 03:57 PM
Default Re: Boring out the B20 (warwagon)
I dont want to use Arias, rather JE with Crower rods.
Old Apr 9, 2003 | 04:24 PM
dfoxengr's Avatar
i run custom arias..but u can do 85 if u want...
Old Apr 9, 2003 | 05:03 PM
Kataku2K3's Avatar
Default Re: Boring out the B20 (hybridvteceg)
Just about all of my friends' CRVTEC motors are running 84.50mm JE 12.0:1-12.5:1 slugs... A couple on stock rods, one on Eagle... Crower rods are awesome, I assume you're just looking at the Econo Billets since there's really no point for a stronger rod with a stock sleeved bottom end... Peace
Old Apr 9, 2003 | 05:27 PM
Default Re: Boring out the B20 (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Just about all of my friends' CRVTEC motors are running 84.50mm JE 12.0:1-12.5:1 slugs... A couple on stock rods, one on Eagle... Crower rods are awesome, I assume you're just looking at the Econo Billets since there's really no point for a stronger rod with a stock sleeved bottom end... Peace</TD></TR></TABLE>
Well I want to do a crazy all motor setup, Skunk2 stage 3 cams, so I hope my sleeves will hold out just fine.
Old Apr 9, 2003 | 05:38 PM
Kataku2K3's Avatar
I mean, I always hear people saying that stock sleeves crack with high compression but all of my friends' motors are still running just fine... They've all been going for over a year with no problems... I dunno... Guess we'll just see... Peace
Old Apr 9, 2003 | 06:10 PM
S9 MECHA KARUMA's Avatar
I just picked up a set of Importbuilder spec wiseco's in 84.5 and their eagle rod combo that corrects the porr rod ratio. The **** is DOPE and worth every penny!
Old Apr 9, 2003 | 06:31 PM
Kataku2K3's Avatar
Default Re: Boring out the B20 (S9 MECHA KARUMA)
Do you know how much the wristpin is moved up on those pistons?? Just wanted to know what R/S is gonna be with your 89mm crank... Peace
Old Apr 9, 2003 | 09:31 PM
AllmotorJunkie's Avatar
IMO if you are planning to build a "crazy motor" why not save yourself drama in the longrun and bulletproof your block now. By bulletproofing I mean sleeved.
BTW, Whats wrong with Arias? Is it a preference that you prefer JE? Or is there something with Arias I don't know about.
Old Apr 10, 2003 | 08:30 PM
the wrist pin in the IB spec stuff is moved up 0.137" as well the rod is longer by 0.137" The psitons are friggin light too 282 grams each!
Old Apr 10, 2003 | 08:31 PM
Default Re: Boring out the B20 (AllmotorJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">IMO if you are planning to build a "crazy motor" why not save yourself drama in the longrun and bulletproof your block now. By bulletproofing I mean sleeved.
I just hear bad stories about the customer service. I dont know too much about them, but all I hear is good things about JE.
RevRipe
Mar 16, 2018 07:02 AM
ek2k
Jan 25, 2005 10:35 AM
Ri5e
Jul 10, 2002 08:23 PM
