overkill sway bar?
Old Apr 9, 2003 | 02:14 PM
LSRydeR's Avatar
Default overkill sway bar?
n00b question sorry *gets ready to be flamed* ...when is it an "overkill" for a sway bar?... is 26mm from Mugen to much of a "overkill" for a LS or will it just be to tail happy?... i know the 22mm is great but i just wanted to see what's your opinion on the 26mm bar
Old Apr 9, 2003 | 02:42 PM
M-Type's Avatar
Default Re: overkill sway bar? (LSRydeR)
ask around the ITR fourm, there are acouple of people there that are running 22mm+ sways. A 26mm will be bad unless you also change the front sways.
Old Apr 9, 2003 | 03:23 PM
VTECPWR's Avatar
Default Re: overkill sway bar? (M-Type)
What size is the front sway bar? I have a feeling that on the ls with a stock front sway bar it will be tail happy.
Old Apr 9, 2003 | 04:30 PM
Malice's Avatar
New User
Default Re: overkill sway bar? (VTECPWR)
22 is perfect. if u get that 26mm bar, then you will definately have to thicken the front swaybar as well
Old Apr 9, 2003 | 08:36 PM
LSRydeR's Avatar
Default Re: overkill sway bar? (MaliceGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">22 is perfect. if u get that 26mm bar, then you will definately have to thicken the front swaybar as well</TD></TR></TABLE>
Okay that's what i thought
tdhjrh
Apr 5, 2017 05:58 AM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
