Cat bolts...WTF is up with the price?
Old Apr 9, 2003 | 01:21 PM
ragejed's Avatar
Default Cat bolts...WTF is up with the price?
Number 5...They are rusted on my cat, I will need to drill them out. They go to 7 bux there!!!, WTF!, Can i just use any normal bolt and lock nut?
Old Apr 9, 2003 | 01:26 PM
wall of tvs's Avatar
Default Re: Cat bolts...WTF is up with the price? (ragejed)
you will need the springs -- other than that, just go to a hardware store, and pick up the proper size.
make sure that they are stainless steel; otherwise you will end up with the same rusted mess you began with.
Old Apr 9, 2003 | 02:01 PM
acatak's Avatar
Default Re: Cat bolts...WTF is up with the price? (wall of tvs)
He isnt talking about the ones with the springs.... those connect the header to the cat. He want the ones that connect the cat to the exhaust. I just got mine from home depot. Run down there and grab some... they were pretty cheap
Old Apr 9, 2003 | 02:33 PM
drumking15's Avatar
Default Re: Cat bolts...WTF is up with the price? (acatak)
go with grade 8...so much better even if the do rust..stainless is weak!!!grade is a sooo much stronger and will take the heat better, stainless will break after a few months trust me on that one! It has to do with the heating process that it takes to make a bolt grade 8...it can handle the heat unlike stainless. peace
Old Apr 9, 2003 | 03:04 PM
PYITR821's Avatar
Default Re: Cat bolts...WTF is up with the price? (drumking15)
you don't need to drill them out.....just tap them out with a hammer. then buy some nuts and bolts from the hardware store.
Baron55
Mar 14, 2007 10:00 AM
TypeR864
Jan 7, 2005 03:22 PM
ShiftDown
Aug 6, 2002 02:36 PM
Kasper.
12
Jul 8, 2002 05:38 PM
ActiveAero
Mar 9, 2002 03:38 PM
