Unsticking Oil rings Idea
Old Apr 9, 2003 | 12:46 PM
Outsane's Avatar
Default Unsticking Oil rings Idea
Ok
So I am trying to think of ways to clean and loosen the oil rings on the pistons without haveing to tear down the engine..
My engine (d16a6) smokes on shifts right now so its the valve steam seals or the oil rings..I figure..if it still smokes after I change the valve stem seals I could try this.
This one is far fetched... How about the ATF trick with Gasoline or Kerosine inplace of the ATF. Fill it up let the gas soak down the rings and let the gas do the work, Pull off oil pan after its soaked for a couple of days and pour in some fresh oil. Let it churn a bit jst like starting a newly rebuilt engine and then starting the car..
Any reasons why this would be harmful?
Old Apr 9, 2003 | 01:57 PM
Chiovnidca's Avatar
Default Re: Unsticking Oil rings Idea (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">
GM top engine cleaner will probably work better than gas or kerosine.
Old Apr 9, 2003 | 02:02 PM
Outsane's Avatar
Default Re: Unsticking Oil rings Idea (TurboD16Chiovnidca)
and use it along the same lines as the ATF trick?
FireInTheHead
Nov 4, 2014 04:15 PM
joss731
Sep 15, 2010 08:50 AM
KyoCivic98
17
Aug 21, 2009 04:21 AM
bigsnorlax
Apr 17, 2009 03:10 PM
Layziebtnh055
Apr 12, 2004 10:03 AM
