NA Type R setups with dyno results, please view
Old Apr 9, 2003 | 12:12 PM
p73's Avatar
p73
Default NA Type R setups with dyno results, please view
I would like to see some results for naturally aspirated ITR motors that have made 190 whp+. If there have been similar post to this before in the past, I would appreciate it if you can send me the link for it. Please attach your dyno results if possible and give us some details on the motor work (no need for suspension & brake setups).
Old Apr 9, 2003 | 12:50 PM
Austin's Avatar
You might want to try the Type-R forum...
Old Apr 9, 2003 | 02:02 PM
All Motor Rex's Avatar
Default Re: NA Type R setups with dyno results, please view (p73)
I don't have a dyno sheet handy, but I was reading about one.
It made 240+whp and 160+lbs of tq. It was big bore (like 84mm), stock crank, no itb's, full exhaust etc, and relatively low compression (for that kind of hp) street car. I will see if I can find the dyno chart, because it was pretty impressive graph.
Old Apr 9, 2003 | 10:57 PM
p73's Avatar
p73
Default Re: NA Type R setups with dyno results, please view (All Motor Rex)
austin...my bad, I will try to post one up on the type R section. All motor rex, when you do find the dyno results, please post!
ge_itr
Apr 24, 2007 11:02 AM
TURTLE_GRIP
Acura TSX
Sep 4, 2006 08:39 PM
xtremecivichb
Jun 9, 2004 12:54 PM
