GSR makes awful Suqeeling noise
Hey guys my gsr makes this awful queeling noise when i get going and im just inching forwards. I think its related to the power steering so i lubricated the belt but it had no result. Its a real embarassing noise and doesnt go away untill i can get the rpms up when im in gear. If anyone has any ideas let me know. Thanks.
Allright i went out and turned on my car and pushed it around so i could check out the sound from outside. It sounds like the sound is most audible around both wheel wells on each side of the front. Does anyone know what goes on in the power steering system there or have a guess at what could need fixing? Thanks.
try adjusting you power steering using the adjuster bolt, my freinds lude had this problem except his went away after it warmed up a bit...i dunno if that would help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">It sounds like the sound is most audible around both wheel wells on each side of the front. </TD></TR></TABLE>
You sure its not your brakes squeeling, not your belts? Mine sqeeks too when i'm moving very slow.. but goes away at higher speeds...
Same deal here man, except mine does it when I'm turning the wheel slowly right to left, like when I'm parking. I checked the ps fluid and its fine. But its an awful squeeling.
Someone told me to spay silicone spray where the rubber meets the shock to make it go away ?
Any suggestions.
Any suggestions.
Well i was pretty sure its power steering fluid related because im leaking PS fluid and it didnt happen till a little while ago. Also It seems to have the most trouble in the cold. I just went out after my car had been sitting in mid 50 degree weather and pushed it around and it didnt really make much noise. I'm gonna have my mechanic look at it soon because besides my blasted exhaust rattling, its the most annoying thing going on with my car at the moment.
92accord95jdmh22a
Apr 24, 2004 10:22 AM
Agent Daimon
10
Nov 4, 2002 04:23 PM
