offsets on tires
Old Apr 9, 2003 | 11:26 AM
ZCHF's Avatar
Default offsets on tires
what kind of offset do i need to run a 205 on a 15" rim. Write now i have a 155 tire and at 10psi, those things just dont do.
thanks
Old Apr 9, 2003 | 11:29 AM
E-AT_me's Avatar
Default Re: offsets on tires (ZCHF)
with a 205, i'd say a +40 or higher..
i run a 195 at +35.. but that rubs sometimes
btw, i run around 32 psi front/rear..
Old Apr 9, 2003 | 11:34 AM
ZCHF's Avatar
Default Re: offsets on tires (Rexman)
cool, so +40 or higher. oh btw, i meant i was boosting 10 psi. haha. i didnt make that clear. thanks though.
brian
Old Apr 9, 2003 | 03:26 PM
SC0TT's Avatar
Im running 205/50-15 tires with a +45 mm offset and its on the boardline of rubbing.
Old Apr 9, 2003 | 03:31 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: offsets on tires (cr-tegra)
holy ****, 155 is like a fricking bike tire! My 13" wheelz/hubcaps had 175-70-13 rubber on them, which I thought sucked *** but 155 is even worse~
Anyway, I'd suggest 195/50-15's because A) That's what I have and they work great and B) that's what I have and they work great. Oh yeah, you're speedometer won't get thrown off too bad with that setup either...
Old Apr 9, 2003 | 03:34 PM
bryant's Avatar
Default Re: offsets on tires (SeaBass)
you can run 205-50-15's but you might rub depending on your drop and offset. Go for some 195-50-15's. No rubbing. Tire cost cheaper. Not really any loss in performance.
Old Apr 10, 2003 | 07:55 AM
ZCHF's Avatar
Default Re: offsets on tires (Bryant)
hmm, so 195 50 15's. that sounds pretty good. Do i need the +40 offset for those?
These bike tires are fun. When im rolling in second gear @ 40 mph, and floor it, boost hits 10 psi and tires become smoke, even from a roll with full traction. I actually took these tires roadracing and spunout at 75 mph. that was fun.
Old Apr 10, 2003 | 08:23 AM
E-AT_me's Avatar
a plus 40 or higher is preferred, but like i said, i am running 195-50/15's bridgestone S-03's on a +35 and it rubs minimal.. in the bumps, that is.. i have a 1 finger gap in the back, and no gap but camber up front.. if i didn't have a gap, i'd be rubbing all the time.
blue_sol94
Dec 29, 2010 04:41 AM
rocko5845
Jan 19, 2010 11:02 AM
2000EJ8
Suspension & Brakes
Mar 17, 2009 10:42 AM
CRX91SE
22
Jan 3, 2008 04:55 PM
yee SERIOUS
Apr 19, 2005 01:36 PM
