Do I need this heatshield?
Old Apr 9, 2003 | 10:13 AM
ragejed's Avatar
Default Do I need this heatshield?
NUMBER: 29
Bolts to the bottom of the car, above the car. I think this one rubs on my shift.
Can I just remove this crap?
TIA
Old Apr 9, 2003 | 10:15 AM
jonsteR's Avatar
Default Re: Do I need this heatshield? (ragejed)
I have removed all my heatshields and it's been fine for 2 years now. I say you don't need it.
Old Apr 9, 2003 | 10:16 AM
Aaron M's Avatar
i would also like to know
ill be installing a header/cat this weekend, and im sure there will be some rubbige
Old Apr 9, 2003 | 10:17 AM
VTECorona's Avatar
Default Re: Do I need this heatshield? (jonsteR)
I took the heatshield off my cat and the one right past the cat towards the rear end that is right under the shifter. 0 problems. Acura even OK'd to do it when I called them about it because it was rattling like a biotch.
Old Apr 9, 2003 | 10:19 AM
NeoGSR's Avatar
Default Re: Do I need this heatshield? (97RedTegGSR)
i've ripped most of mine off, no probs so far
.RTErnie's Avatar
the only thing that i have found from doing this is...when you run your car hard it heats up the shift ****(mine is metal) and the the shifter gets heat soak'd and burns your hand. just FYI.
Old Apr 9, 2003 | 10:31 AM
startroops's Avatar
Default Re: Do I need this heatshield? (RTErnie)
Depends on your ****, my Razo metal one feels fine but I can feel the shifter itself warming up.
I have taken all the heatshields off my car and not 1 problem so far... it did get a tad louder though.
Old Apr 9, 2003 | 10:35 AM
ragejed's Avatar
Default Re: Do I need this heatshield? (startroops)
I drive with gloves. No heat problem here.
Old Apr 9, 2003 | 11:00 AM
wall of tvs's Avatar
no heatshield = no rattles/buzzes = no problems
on a side note, many who experience the 3000rpm buzz on the gsr take note -- your a-pipe on the header is causing it. remove that pos, and get a comptech one like me
Old Apr 9, 2003 | 11:45 AM
WiggiE's Avatar
New User
Default Re: Do I need this heatshield? (wall of tvs)
The only heatshields I would keep are the ones around the cat. The rest can be chucked.
Old Apr 9, 2003 | 12:17 PM
ragejed's Avatar
Default Re: Do I need this heatshield? (WiggiE)
How about the ones under the gas tank?
Old Apr 9, 2003 | 12:33 PM
RedKroovy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wall of tvs &raquo;</TD></TR><TR><TD CLASS="quote">no heatshield = no rattles/buzzes = no problems
on a side note, many who experience the 3000rpm buzz on the gsr take note -- your a-pipe on the header is causing it. remove that pos, and get a comptech one like me </TD></TR></TABLE>
anyone got a pic of the heat shield he is talking about cause I don't want to remove the wrong one
Old Apr 9, 2003 | 01:01 PM
JimBlake's Avatar
Default Re: Do I need this heatshield? (RedKroovy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedKroovy &raquo;</TD></TR><TR><TD CLASS="quote">anyone got a pic of the heat shield he is talking about cause I don't want to remove the wrong one </TD></TR></TABLE>
He's talking about the A-pipe itself, #10 or #11 in the picture at the top of the thread. It's a pipe-inside-of-a-pipe, and the inner pipe buzzes against the outer.
Old Apr 9, 2003 | 01:24 PM
Default Re: Do I need this heatshield? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">He's talking about the A-pipe itself, #10 or #11 in the picture at the top of the thread. It's a pipe-inside-of-a-pipe, and the inner pipe buzzes against the outer.
yup...you have to replace the header to get rid of that buzz -- don't even bother getting a new oem one, either
Old Apr 9, 2003 | 01:27 PM
illi Adik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonsteR &raquo;</TD></TR><TR><TD CLASS="quote">I have removed all my heatshields and it's been fine for 2 years now. I say you don't need it.</TD></TR></TABLE>
Same here.
Old Apr 14, 2003 | 10:20 AM
Aaron M's Avatar
Default Re: Do I need this heatshield? (Jackson4Door)
i just installed my header/cat and my exhaust was pused back about an inch or so. I think it rubs against #30 in the picture. Would taking this off be OK?
Old Apr 14, 2003 | 10:53 AM
tC_Dragon's Avatar
Default Re: Do I need this heatshield? (SilverB18C1)
hey aaron.. did you try takin off the heatshield n bending that sucker? or bangin it to shape while still up there? haha... maybe that'll werk.
Old Apr 14, 2003 | 11:01 AM
Aaron M's Avatar
Default Re: Do I need this heatshield? (pdcdragon)
havent tried bending it yet, ill give it a shot, if not then off it goes
Old Apr 14, 2003 | 11:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I have no heatshields at all on the actual exhaust, except for the one that covers the manifold in front (the rear half is gone). The only other one I have is that one that bolts to the car above the cat. All my shields on the cat itself and the rest of the pipe under the floorboard are gone. I even parked in 2-ft. tall grass one time and it didn't even do anything.
Old Apr 14, 2003 | 12:03 PM
Aaron M's Avatar
Default Re: Do I need this heatshield? (PatrickGSR94)
off it goes then
OT: anyone wanna buy a #30 heatshield?
dfJDM
Jan 5, 2011 07:27 PM
sickofitall1113
Oct 17, 2006 11:21 AM
LSintegra
Jan 22, 2006 02:20 PM
abeaujuin
Sep 26, 2003 10:09 AM
APP95bomexLS
Jun 2, 2003 07:41 AM
