Dropping a ZC into my car, I have some quick questions though...
Old Apr 9, 2003 | 10:13 AM
FourthGenHatch's Avatar
Default Dropping a ZC into my car, I have some quick questions though...
Before I attempt to do this I want to know a few things. I know that by putting the DX DPFI manifold on the ZC I can get it running without any wiring I don't think which is what I would like to do just to get the car running so I can take it to school. I also plan to use the DX tranny, I know it will bolt up but do I need to use the DX flywheel or anything? I know some of this sounds dumb but I just want the car running. I will do the MPFI swap later on but for now I just need to be able to get to school and work as I'm low on cash.
Old Apr 9, 2003 | 10:16 AM
keithv's Avatar
Default Re: Dropping a ZC into my car, I have some quick questions though... (FourthGenHatch)
you will still need to do the dist. wiring since its different on the ZC. the ZC has an external cam angle sensor on it...
and i'm not sure if the DX manifold will even bolt up the ZC head.
Old Apr 9, 2003 | 10:24 AM
zCivic's Avatar
Default Re: Dropping a ZC into my car, I have some quick questions though... (breaka_1_9)
DX intake manifold will not bolt to a ZC accually no SOHC D series will bolt up. There was old post about the difference but cann't find it . The Cam angle sensor is on the exhaust cam so you can still use you DX diz if it bolts up right. To make it work gonna have to go MPFI sorry to say.
Old Apr 9, 2003 | 10:38 AM
Default Re: Dropping a ZC into my car, I have some quick questions though... (zCivic)
Are your POSITIVE? I remember someone on another board saying their ZC was DPFI because he didn't have time to do that wiring. I thought I even saw pictures of it. Unless I don't know, maybe it was a SOHC one after all.
Old Apr 9, 2003 | 10:46 AM
zCivic's Avatar
you can stay DPFI if you use a SOHC D-series or SOHC ZC because all the intake manifolds for the SOHC are the same. ZC bolt patterns are way off you can drill you DPFI intake and use it or cut and past it but it will not bolt on with out any mods. I'm sure
crx(gator)'s Avatar
wtf is the point of having a zc then...dpfi zc...
Old Apr 9, 2003 | 10:52 AM
Well will the DX tranny work at least then?
Honestly, how hard is it to do the MPFI swap. I see lots of instructions and they are rather simple but no one ever has any pictures.
Old Apr 9, 2003 | 11:02 AM
zCivic's Avatar
yeah tranny will work... DPFI-MPFI wiring is pretty stright forward. Run 4 wires from the ECU to the engine and swap 2 wires at the ECU then add injector resistor box. I can help if you run into any problems. I think I can do it in my sleep.
Old Apr 9, 2003 | 11:12 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Well will the DX tranny work at least then?
Honestly, how hard is it to do the MPFI swap. I see lots of instructions and they are rather simple but no one ever has any pictures.</TD></TR></TABLE>
yes the dx tranny will work. just use your dx clutch, flywheel and PP.
the hardest part of the MPFI swap is getting the 2 injector plugs and the injector resistor box.
Old Apr 9, 2003 | 11:18 AM
Injector plugs? Doesn't my ZC come with a harness that would perhaps have those plugs?
Old Apr 9, 2003 | 11:27 AM
zCivic's Avatar
its 1 silver finned box with 5 wires and a green plug your ZC harness may have it never can tell til you look. this is one...
Old Apr 9, 2003 | 11:31 AM
E-AT_me's Avatar
i may have some injector plugs.. i'll check around my house..
Old Apr 9, 2003 | 11:33 AM
Are there any parts on my D15 that will switch over to the ZC? My starter is new I'm pretty sure that will switch over. What about the thermostat, my DX one is like 2 weeks old, might as well swap it if it works? Anyone have a site or a list of which parts fit the ZC?
Old Apr 9, 2003 | 11:34 AM
Default Re: Dropping a ZC into my car, I have some quick questions though... (Rexman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexman &raquo;</TD></TR><TR><TD CLASS="quote">i may have some injector plugs.. i'll check around my house..</TD></TR></TABLE>
Yeah if any of you guys have the Resistor Box or these plugs I will be interested in buying them.
Old Apr 9, 2003 | 11:51 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Injector plugs? Doesn't my ZC come with a harness that would perhaps have those plugs?</TD></TR></TABLE>
if your ZC comes with an engine harness then you should have the plugs. i just don't know if the motors come with harnesses, too.
Old Apr 9, 2003 | 12:07 PM
zCivic's Avatar
Engine Mounts:-----1988-91 CRX/Civic
Timing Belt:-----1988 Prelude 2.0
AC Compressor / Parts:-----1989-91 CRX/Civic
Throttle Body:-----1988-91 CRX/Civic
TPS:-----1988-91 CRX/Civic
ECU:-----1989-91 CRX/Civic Si, 88-89 Integra 5-spd, 89-91 ZC
Intake:-----1988-91 CRX/Civic
Headers/Exhaust Manifold-----88-91 CRX can be used port will not be perfect---Ideal is DC 86-89 Integra Top with 88-91 CRX downpipe---(I use port matched GUDE 4-1 Header)
Plug Wires:-----1986-89 Integra
Spark plugs:-----1986-89 Integra or 1988-91 CRX/Civic----- NGK BCPR6E-11
Distributor Cap:-----1988-91 CRX/Civic 1988 Integra
Distributor Rotor:-----1988-91 CRX/Civic 1988 Integra
Head Gasket:-----1988 Prelude
Intake Gasket:-----1988 Integra
Exhaust Gasket:-----1988 Integra
Water Pump:-----1989-91 CRX
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic or 1986-89 Integra
also your DX starter will work....
hondacivic90zc
12
Apr 2, 2008 07:17 AM
myhondasrusty
23
Jul 24, 2006 01:43 PM
MUGENKHID
Jul 1, 2005 06:40 PM
psicrxsi
Apr 26, 2005 06:55 PM
sCeRaXn
13
May 15, 2002 08:59 PM
