bigger rad in hybrids?
Old Apr 9, 2003 | 09:47 AM
racin-type's Avatar
Default bigger rad in hybrids?
ok to my knowledge you should get a bigger or at least a more efficient radiator when you swap to a bigger engine. i've seen b18's, b16's and even h22's wit the same stock rad the civic chassis came wit and even some with turbo's. now isn't that a cause for concern or are those configurations ok?
please shed some light on this lil subject as i'm carefully planning my swap. thanks
Old Apr 9, 2003 | 10:00 AM
sleeprhatch's Avatar
Default Re: bigger rad in hybrids? (racin-type)
save your self from headaches, get a bigger rad
Old Apr 9, 2003 | 10:10 AM
V3locity's Avatar
Default Re: bigger rad in hybrids? (sleeprhatch)
dual core!!!
Old Apr 9, 2003 | 01:18 PM
nsxmatt's Avatar
Default Re: bigger rad in hybrids? (illdezignzls)
A dual-core would be ideal but not nessasary.
Many people run with B-series swaps with the stock radiator with no problems. If your going H22 or you have A/C I would advise a upgrade but it's not required. Before you spend the money see how your car does with the stock one. I've run a year in Florida summer drive-thru's with a stock radiator, B16, and it's kept cool.
Old Apr 9, 2003 | 01:33 PM
Newman's Avatar
New User
Default Re: bigger rad in hybrids? (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">A dual-core would be ideal but not nessasary.
Many people run with B-series swaps with the stock radiator with no problems. If your going H22 or you have A/C I would advise a upgrade but it's not required. Before you spend the money see how your car does with the stock one. I've run a year in Florida summer drive-thru's with a stock radiator, B16, and it's kept cool.</TD></TR></TABLE>
Percisely. Some H22 swaps come out and run fine (no overheating) with just the stock single-core Civic radiators still in them. Some want to run hotter so we recommend changing out the radiator for a dual core or larger/GSR one and it solves their problem. Everyone has a different car so they're all going to work differently. Try your current setup... if it overheats or starts to run warmer than before, first try flushing your radiator fluid and checking your thermostat. If that doesn't change it, then upgrade to a "bigger" radiator.
Old Apr 9, 2003 | 02:40 PM
junglerunna's Avatar
Default Re: bigger rad in hybrids? (Newman)
Also a dual core radiator is not even that expensive I mean for a little under $200 I got a gsr radiator which is full length and dual core, so I mean I nots that much considering you do not want your motor you spent all those blood sweat and tears on to over heat.
Old Apr 9, 2003 | 04:02 PM
redlineh22a's Avatar
Default Re: bigger rad in hybrids? (junglerunna02)
A good Del Sol Vtec radiator is a good investment, cheap too!
Most swaps i've seen and turbos work fine with half rads.
Old Apr 9, 2003 | 04:04 PM
The del sol vtec radiator is a easy and good investment.
I have seen many b18's some with boost that use half rads and they work fine.
Old Apr 9, 2003 | 04:17 PM
drvfast's Avatar
i have my stock radiator with my b16 swap and its been fine
Old Apr 10, 2003 | 07:05 AM
Burke's Avatar
Banned
Default Re: bigger rad in hybrids? (drvfast)
when flushing my coolant, i went ahead and bought a new $120 gsr rad for my jdm b18c. just had to fab some brackets and wahlaa! looked a lot better with a full length rad, i couldnt see my 4-1 headers anymore.
later
Old Apr 10, 2003 | 09:08 AM
Drews Bitch's Avatar
Default Re: bigger rad in hybrids? (Burke)
it's called security.. spending a $100 is better than spending a $1000
but you could run fine either way. my 2 cents is just go duel core, but i'm paranoid
Old Apr 10, 2003 | 09:53 AM
Hybrid Beast's Avatar
Yup I have a JDM B18C in mine running on the stock rad and i have had no problems at all.
Old Apr 10, 2003 | 01:24 PM
Braco11's Avatar
Default Re: bigger rad in hybrids? (Hybrid Beast)
Where's a good/cheap place to get a dual core radiator from a del sol??
Old Apr 10, 2003 | 06:00 PM
racin-type's Avatar
Default Re: bigger rad in hybrids? (Braco11)
thanks guys for the replies. thats what i thought too get the bigger rad and save myself some trouble or if i have any trouble at all.
well i'm goin with usdm b18c with nitrous probably end at 100 shot. are the delsol vtec dual cores better than the gsr ones or vice versa? or should i just get a brand new all aluminum one from fluidyne or something?
thanks again
Old Apr 10, 2003 | 06:03 PM
Suprdave's Avatar
I have a JDM ITR Radiator for sale...IM me
Suprdave
Old Apr 10, 2003 | 11:09 PM
RangerDan's Avatar
Default Re: bigger rad in hybrids? (Suprdave)
I had the same question thanks for the informative post guys!
91efbluehatch
13
Jul 19, 2011 09:45 AM
crxpwr1
31
Jul 17, 2006 07:36 AM
Greasemonkey
31
Jan 5, 2005 07:10 AM
black-hatch
May 2, 2003 07:44 AM
b18c1civic95
Feb 1, 2002 11:29 AM
