question/problem about installation of short shifter
I just installed a new short shifter...works fine and everything but I am having trouble with my shift **** (mugen c/f w/ metal) getting hot. I made sure that I put the rubber cover back on in the top portion of the shift assembly. Did I miss something else possibly underneath? A friend and I did the install and he said he put everything back, and I double checked up top too!
Any info on this matter would be greatly appreciated.
thanks in advance
Jason
thanks in advance
Jason
that's normal with me on both of my cars. not the **** itself, but the shifter gets hot...
[Modified by blaze, 3:05 PM 6/23/2001]
Well, it didn't happen like that with my stock shifter and I had the same ****???
Big Phat R---hehehe yeah, maybe I should have...it is so hot I can barely keep my hand on it (the metal part around the top, I have to use the C/F portion as it doesn't retain the heat)
Short throw will sit 1/2" to 3/4" closer to the exhaust than the stock one. This makes the space between exhaust and shifter generally less than 1/2" so, sorry but you're gonna have to get used to it. (or bend the exhaust hangers so it sits lower!
thanks for the responses guys, i'll see if I can rig something to make theheat dissipate better.
