stearing column shaking during high speeds and braking (recently changed my springs)
Old Apr 8, 2003 | 10:02 PM
natrl's Avatar
Default stearing column shaking during high speeds and braking (recently changed my springs)
k..heres my problem...before i had neuspeed race springs on my integra....i had no problems with it...until i installed eibach pro kits...i know i should get an alignment, but changing the springs shouldnt cause my stearing column to shake on the freeway and braking...i followed the instruction in the owners manuel...what could be causing this...thanks
Old Apr 8, 2003 | 10:10 PM
AZHottie
Guest
Posts: n/a
Default Re: stearing column shaking during high speeds and braking (natrl)
bump
same here but mine is stock suspension
Old Apr 8, 2003 | 10:38 PM
GS-RAW415's Avatar
well, what tha problem most likely is, is u need new rotors or jus need tha old ones resurfaced. just do a brake inspections and look into the rotors because im almost positive thats the problem.
Old Apr 8, 2003 | 10:41 PM
216.226.142.95:27016's Avatar
check your wheels, tires, and brake pads, and rotors.
Old Apr 8, 2003 | 10:46 PM
hootb18's Avatar
Default Re: stearing column shaking during high speeds and braking (216.226.142.95:27016)
Check to make sure your tires are properly inflated, also make sure to properly torque the lug nuts. If that doesn't work, maybe check into getting your rotors resurfaced.
Even with changing only springs, you should still get an allignment. Different spring rates and heights can cause you to go out of spec.
Old Apr 8, 2003 | 11:56 PM
GSRdriver's Avatar
Default Re: stearing column shaking during high speeds and braking (hootb18)
What all these guys said. Mine did the same thing, turning out I had warped rotors. Just take your car to your local shop and they'll fix it for you.
Could be rotors, alignment, I woudn't think your springs would cause this.
Old Apr 9, 2003 | 04:33 AM
IC x Prince's Avatar
New User
Default Re: stearing column shaking during high speeds and braking (GSRdriver)
if you also just lowered or changed the suspension, get an alignment. mine did that on all my cars until i got an alignment.
Old Apr 9, 2003 | 04:33 PM
TEXN3's Avatar
Default Re: stearing column shaking during high speeds and braking (UltraPrince)
are your tires properly balanced?
Old Apr 9, 2003 | 04:45 PM
acatak's Avatar
Default Re: stearing column shaking during high speeds and braking (texnteg)
That happened to me... I just had to get my tires balanced then it was fine.... but does anyone know the torque spec for lugnuts?
Old Apr 9, 2003 | 05:12 PM
swipester's Avatar
Could be any of these problems: warped rotors, wheel balancing required, rack & pinion worn out, alignment needed.
Old Apr 9, 2003 | 05:30 PM
EL Vap133's Avatar
Did you rotate them tires? BTW, ******* kick *** Avatar you got there...
Old Apr 9, 2003 | 05:53 PM
hootb18's Avatar
Default Re: stearing column shaking during high speeds and braking (acatak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acatak &raquo;</TD></TR><TR><TD CLASS="quote">That happened to me... I just had to get my tires balanced then it was fine.... but does anyone know the torque spec for lugnuts?</TD></TR></TABLE>
80 lb ft.
Old Apr 9, 2003 | 06:04 PM
acatak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hootb18 &raquo;</TD></TR><TR><TD CLASS="quote">
80 lb ft. </TD></TR></TABLE>thanks
Old Apr 9, 2003 | 07:22 PM
Turbo Powa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hootb18 &raquo;</TD></TR><TR><TD CLASS="quote">Check to make sure your tires are properly inflated, also make sure to properly torque the lug nuts. If that doesn't work, maybe check into getting your rotors resurfaced.
Even with changing only springs, you should still get an allignment. Different spring rates and heights can cause you to go out of spec.</TD></TR></TABLE>
Old Apr 9, 2003 | 11:43 PM
natrl's Avatar
Default Re: stearing column shaking during high speeds and braking (Panda EK)
koo...thank everyone
Old Apr 10, 2003 | 12:24 AM
Regal's Avatar
Ladies and gentlemen we are floating in space...
I had that exact problem before, all it took was a balancing and an alignment and the problem was gone.
Old Apr 10, 2003 | 06:06 AM
Rory Breaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">check your wheels, tires, and brake pads, and rotors. </TD></TR></TABLE>
Haha....could you be any LESS specific?
First things first, get an alignment/wheel balancing. A vibrating steering wheel under braking usually indicates warped rotors, but if you just put the springs in, I would first suspect something related to that.
Old Apr 10, 2003 | 06:09 AM
Evilteg's Avatar
rotation
balance
align
Old Apr 10, 2003 | 06:10 AM
junk yard sol's Avatar
mine did that as well could be loose wheel or lugnuts are uneven but my car was doing that cause one of my pistons was stuck on my caliper it was not calapsing properly...
Old Apr 11, 2003 | 12:24 AM
GreenEyedBandit's Avatar
I agree it could be the rotors
Extreez
Aug 19, 2006 07:48 AM
NXBen
May 7, 2004 10:38 AM
hYpE-R-29
Jun 22, 2003 10:10 AM
akhom
Jan 6, 2002 09:20 AM
