Horn switch
Hey my horn just stopped working. I checked the horn itself & it beeps, i also checked the wire under the bumper and it works, so its in the steering wheel.
Has anyone ever had this problem, how do i check the switch, what about the SRS?
I can only find 1 screw behind the wheel and its and SRS connector, I'm lost...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">My brake lights and horn havent worked for a few months
is cruise control directly related to the horn? I tore my cruise control out recently.
yours might be the fuse.
cruise works fine, and so do my stop lights, i checked the fuse, not that lucky. I need to know how to fix or change the horn switch. Allthough neither of the two work horn buttons work!
I'm in the same situation as you... my horn doesn't work at all!... switches on the steering wheel don't work also when i press my panic button on the alarm all you see is my lights flashing but no horn!... checked the fuse but it's not burnt out... there's something else wrong with it... anyone know whats wrong with that?
i know on the schematic of the cruise and horn that the horn is connected to the cruise control some how....i'd bet on that.....my cruise doesn't work and my horn does....i can't figure that one out yet....
no horn of cruze for me any sujestions is their a relay i can check and where at, no cruze fues, and my brake lights work but when i had my horns on the shorted out or something and smoked alittle and blew the brake/horn fues, removed the horns and no more problems just no horn any help would be great.
thanks
thanks
ophdehEEzY
Jun 25, 2003 08:12 PM
