B16 Swap Question
Old Apr 8, 2003 | 09:21 PM
bottledcrx's Avatar
Default B16 Swap Question
Ok i'm doing a b16 swap into my cousins 89 crx si, now i know you need to ad 4 wires for vtec, 2nd o2, knock sensor and oil pressure.. Now a couple people i know said the ecm needs to see a vss signal for vetc to engage.. will the vss on the back of the cluster send the signal and are they pinned in the right location, also what do i do with the thing that sits under the speedo cable on the tranny and has the 2 hoses coming out of it... Thanks for any help
Old Apr 9, 2003 | 02:30 AM
chad174's Avatar
Default Re: B16 Swap Question (bottledcrx)
if you're staying obd-0, don't worry about it, i believe.
Old Apr 9, 2003 | 04:23 AM
bottledcrx's Avatar
Default Re: B16 Swap Question (chad174)
ok, i'll give it a shot....
Old Apr 9, 2003 | 04:48 AM
zCivic's Avatar
with the B16 swap in EF's the VSS is in the Gauge Cluster on that one. Its pinned correctly already at the ECU for a PR3/PW0. The hoses you can leave open or loop between them. They was for powerer stearing which EF didn't come with
Old Apr 9, 2003 | 06:04 AM
bottledcrx's Avatar
Default Re: B16 Swap Question (zCivic)
Thanks, That's what i was looking for
stevenstixx
15
Jul 29, 2014 02:28 PM
JayDeeMmm
Aug 14, 2012 11:39 AM
ltzracer
Nov 17, 2006 06:09 AM
jamesknightsi
Jul 24, 2006 10:16 PM
KevronsEG
Feb 3, 2002 06:09 PM
