b16a dizzy?
Old Apr 8, 2003 | 09:08 PM
LD_EGSICK's Avatar
Default b16a dizzy?.....
serech isn't really been workin right and i need to know asap.
i got a first gen jdm b16a from hmotorsonline.com n the dizzy was bad, what usdm dizzy can i replace it with? could i use my dizzy from my 91 si?
Modified by mysiqu at 5:08 AM 4/10/2003
Modified by mysiqu at 6:01 AM 4/10/2003
Old Apr 8, 2003 | 09:23 PM
RCautoworks's Avatar
Default Re: b16a dizzy? (mysiqu)
Nope, I'm pretty sure the only one that will fit close is an older integra one, but then you need to cut one of the legs off. But don't quote me on that, not really sure. I know the si one won't work though.
Old Apr 8, 2003 | 10:52 PM
Noahk's Avatar
90-91 integra and you do need to cut one of the arms but it will work fine with 2 arms.
Old Apr 9, 2003 | 04:08 AM
zCivic's Avatar
Default Re: b16a dizzy? (Noahk)
The civic will work just the legs may not line up. But in a pinch you could always cut and use large washer. If your strapped for $$$$ and have a xtra SI your not using cut it to fit. Or swap the SI internals into the B16 electronicly there the same thing, just the casing is different
Old Apr 9, 2003 | 05:39 AM
LD_EGSICK's Avatar
Default Re: b16a dizzy? (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">The civic will work just the legs may not line up. But in a pinch you could always cut and use large washer. If your strapped for $$$$ and have a xtra SI your not using cut it to fit. Or swap the SI internals into the B16 electronicly there the same thing, just the casing is different</TD></TR></TABLE>
ok then, dame i'm stuck on money really bad, i was thinkin of gettin a new dizzy off of hmotorsonline.com http://www.hmotorsonline.com/s...40005 but they want 150. soo i guess i should just swap the internals.but has any one ever done this as well? need help asap.
-alex
Old Apr 9, 2003 | 06:10 AM
zCivic's Avatar
done it.... You needs some tamper proof star bits and be extemly careful because the screws in the diz will break very easily. Just unscrew everything and swap it over. Shafts, sensors, wheels are all the same for the MPFI.
Old Apr 9, 2003 | 06:32 AM
Rob!'s Avatar
if the rotor still turns on the dizzy then the problem isnt your dizzy itself...its the internals...i got all new internals for mine. i have an ignitor if you need one. i got a new one and it turned out that mine was fine.
Old Apr 9, 2003 | 10:58 AM
LD_EGSICK's Avatar
Default Re: b16a dizzy? (b16hf)
what kind of cap n rotor would i use then cause i just got the 90 to 91 intergra cap n rotor would it still work?
Old Apr 9, 2003 | 11:00 AM
Kris's Avatar
What is this dizzy I keep hearing about?
EDIT: err I think I got it, Distributor if I am correct.
Modified by Kris at 8:14 PM 4/9/2003
Old Apr 9, 2003 | 11:16 AM
zCivic's Avatar
Default Re: (Kris)
yeah thats the cap and rotor that you use. Prior post about the bearing is correct, if the sensor is all thats bad you can swap them with any of the other sensors theres a total of 3 available in a SI diz. DX have 2 and those will also work. Colors would be different but also in a pinch will work. If the bearing is bad its ezer to swap the whole shaft alone.
Old Apr 9, 2003 | 08:00 PM
LD_EGSICK's Avatar
Default Re: (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats the cap and rotor that you use. Prior post about the bearing is correct, if the sensor is all thats bad you can swap them with any of the other sensors theres a total of 3 available in a SI diz. DX have 2 and those will also work. Colors would be different but also in a pinch will work. If the bearing is bad its ezer to swap the whole shaft alone.</TD></TR></TABLE>
should i use the thingy(i don't know the name of it but the rotor srews on to it n on the other side is goes into the head, that connect to the cams) thats on my si dizzy on the the b16a dizzy casing or use the one in the b16a dizzy? casue the one on my si says pm6. my b16a the rotor melted on n cover up the screw, soo i got to cut it out.
Old Apr 10, 2003 | 04:31 AM
zCivic's Avatar
Default Re: (mysiqu)
is it the shaft with the 3 wheels 1 with 16teeth, 4 teeth then single tooth?? Then it has a metal plate with 3 screws that hold it into place?? to remove that you remove the 3 tamper screws carfully or will snap, then on the outside where it goes, there a clip need to take off then a pin that you push out then the shaft then the part that goes into head (too early cann't think of name) will slide off with 3 black washers and the whole shaft can be slid out.....
Mr.Chow
May 12, 2008 01:57 PM
jonezyboy6
Jan 24, 2008 04:53 AM
zenon8890
Apr 29, 2007 03:55 AM
racerx156
Dec 17, 2003 05:30 PM
91sifreak
Jul 5, 2001 03:19 PM
