type R pistons in ls block
Old Apr 8, 2003 | 08:31 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default type R pistons in ls block
i am goin to purchase a b18a and the rings on 3 of the cylinders are bad, and i can get a good deal on a set of type r pistons with rings, i was wondering if the r pistons would work with the ls rods. if so im going to get the block honed and put em in, thanks for any responses
Old Apr 8, 2003 | 08:36 PM
HKJ's Avatar
HKJ
Default Re: type R pistons in ls block (coptzer)
i'm pretty sure they will work. i was about to purchase some itr pistons myself, and the seller told me they will fit the ls rods -- but don't take my word for it.
somebody help the guy out.
Old Apr 9, 2003 | 10:30 AM
Default Re: type R pistons in ls block (HKJ)
anyone?
Old Apr 9, 2003 | 10:34 AM
startroops's Avatar
The only piston that will fit on a LS rod without any mod is the B16A ones.... all others need a slight shaving on the rod in order to fit. It's not a big job and most machine shop will do it for you.
Now the question is, should you shave the rod of the pistons.... Most people go with shaving the rods but once in a while you'll hear people machining the pistons...
But I'm 99% sure that it should be done on the rod. HTH.
Old Apr 9, 2003 | 10:47 AM
Default Re: type R pistons in ls block (startroops)
by shaving the rod? how much should be shaved and im sure it should be shaved equally (same amount from each side to keep in balance?) im not too sure on this kinda things so any help is appreciated
Old Apr 9, 2003 | 12:09 PM
IC x Prince's Avatar
New User
well my friends LS has itr piston, with LS rods...he didn't do any modification to his rods.
thegeezerkid
Oct 31, 2008 06:44 AM
ea_hatch
Jan 15, 2005 06:43 AM
Dancing is Forbidden
Dec 23, 2003 09:36 PM
lsvtec101
15
Dec 1, 2003 08:34 AM
infamousALLMTR
Jun 3, 2003 03:33 PM
