ITR Sway Bar Questions
So I'm at http://www.acuraautomotiveparts.org and I'm ordering the ITR Sway bar kit. So the prices have gone up is one thing and for the description instead of it saying Rear Sway Bar...it says Spring, 22mm....is that correct?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmySH »</TD></TR><TR><TD CLASS="quote">can you double check how much exactly it is so i know i'm ordering the right thing?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra »</TD></TR><TR><TD CLASS="quote">so what else is needed?
besides the bar, and the BSQ/Beaks mounting kit...</TD></TR></TABLE>
here you go
Here are the Acura parts that will be need:
1.) 52300-ST7-Z01 rear swaybar ($57.30)
2.) 52315-ST7-Z01 swaybar bushing ($3.57) (2 needed)
3.) 52308-SS0-000 bushing bracket ($4.86) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.41) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($3.98) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($1.98) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.08) (2 needed)
here you go
The prices are a little different now....I'll post up what I bought...keep in mind I skipped one of the #'s because I have a gsr.
Here's mine as of yesterday:
This is only from http://www.acuraautomotiveparts.org...I still need to get the BSQ kit from http://www.geocities.com/bretq/mounting_kit.html
1) 52300-ST7-Z01 SPRING, RR. (22MM) 1 $64.15 $64.15
2) 52308-SS0-000 HOLDER, RR. 2 $5.44 $10.88
3) 52315-ST7-Z01 BUSH, RR. STABILIZER 2 $4.00 $8.00
4) 52316-ST7-Z00 BUSH, STABILIZER END 2 $1.57 $3.14
5) 90175-ST7-Z00 BOLT (8X35) 2 $2.22 $4.44
6) 94050-08080 NUT, FLANGE (8MM) 2 $0.08 $0.16
Subtotal $90.77
Tax $0.00
Handling Charge $4.95
Total $95.72
Subtotal $90.77
Tax $0.00
Total $95.72
if u want some pics n **** to help you with the install.. go to my site.. i have an install guide on it as well....
My Site: jus go to the "DIY" section
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRydeR »</TD></TR><TR><TD CLASS="quote">anyone know if it's okay to put a ITR sway bar on stock ride height or will it tear the subframe?</TD></TR></TABLE>
i have it on stock ride height, and havent torn anything during my sprited driving
for the ITR sway
for "BSQ" and "pcdragon" for their writeups and support!!!
the difference!!!! A MUST FOR ALL INTEGRA OWNERS(im sure thats been said before)!!
for the ITR sway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beefpigs »</TD></TR><TR><TD CLASS="quote">Get the BSQ kit and you will be fine.</TD></TR></TABLE>
Yep. Without the BSQ or Beaks, you'll eventually have the bolts tear the subframe from stress.
the link for wat? the instal??
u can go to BSQ's site
or u can to the diy section of My SIte
like i mentioned a couple replies ago!!!
