Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Hot Lap Timer: Is the cable a regular phone cord?
Old Apr 8, 2003 | 05:47 PM
bulldog_RS20's Avatar
Default Hot Lap Timer: Is the cable a regular phone cord?
I recently scored a used Hot Lap system and am trying to figure out a decent install where I can alternate the position of the receiver from one side of the car to the other.
The problem is the 7' cord is way too short for this idea (I'm mounting behind the front seat - aimed out the back side window). Is the cable supplied in the Hot Lap System just and ordinary phone cord? )Plus, I remember a replacement costing something like $7.00 which I thought was way too much)
Thanks
Greg
Toyos: check
Hot Lap: check
Momo wheel: check
Radio system: check
Gauges: check
Entry $$: ****!
[Modified by bulldog_RS20, 2:49 AM 4/9/2003]
Old Apr 8, 2003 | 06:11 PM
JeffS's Avatar
Default Re: Hot Lap Timer: Is the cable a regular phone cord? (bulldog_RS20)
A regular phone cable will probably not work. Most phone cables reverse the wiring order from one end to another. You could cut one end off and put a new one on... Maybe you could track down a cable that doesn't reverse.
Old Apr 8, 2003 | 06:50 PM
sjasmund's Avatar
I had to make one for the same reason and it's a crossover cable.
Old Apr 8, 2003 | 06:52 PM
ITACivic's Avatar
I wen to the product web site and read that any RJ11 or RJ12 straight through cable wll work. Twisted pair will ruin the unit.
Old Apr 8, 2003 | 06:53 PM
sackdz's Avatar
Default Re: Hot Lap Timer: Is the cable a regular phone cord? (sjasmund)
It's also a 6 wire cable instead of the standard 4. You might be able to find it online... I haven't gotten around to looking myself.
Old Apr 8, 2003 | 07:18 PM
Default Re: Hot Lap Timer: Is the cable a regular phone cord? (sackdz)
Thanks to All...
I did a garage test and sure 'nuff, the phone cord is reversed. I'll hit up Radio Shack for the parts...
Old Apr 9, 2003 | 12:45 AM
Tyson's Avatar
if you cant locate an actual cord that will work, you can just invest in a telephone plug crimper and match the wires and crimp the plugs yourself.
cua0
May 10, 2007 05:16 PM
mike93eh
May 20, 2005 06:20 AM
madhatter
Dec 7, 2001 12:52 PM
