mugen twin loop? spoon n1?
Old Apr 8, 2003 | 05:47 PM
ITSUKA's Avatar
Default mugen twin loop? spoon n1?
hey guys just have sum trouble deciding which exhaust system to get could you plz list your pros and cons between the two mugen twin loop or spoon n1? it be great to get your opinions also the price differences as well
Old Apr 8, 2003 | 05:50 PM
skafia's Avatar
25 Year Member
Default Re: mugen twin loop? spoon n1? (ITSUKA)
Mugen Twinloop -> Quiet
Spoon N1 -> Loud as fawk.
Both pretty good choices, if you get the Spoon N1, you'd have to get a B-Pipe as well
Old Apr 8, 2003 | 05:51 PM
B2FiNiTY's Avatar
Mugen:Expensive but catback and quiet
Spoon: lightweight, loud, cheaper but only axle back
Old Apr 8, 2003 | 05:52 PM
Champ R's Avatar
Well the spoon n1 is going to be LOUD, and the mugen more like stock, but sounding sweet in the vtec range. The mugen is one of the best quality exhausts made, but also very expensive, the spoon n1 axle back is around $400 i believe.
Old Apr 8, 2003 | 06:07 PM
Mike M's Avatar
Founding Member
Default Re: mugen twin loop? spoon n1? (skafia)
Please Do Not spread misinformation.
1.) Spoon N1 is NOT that loud compared to most N1 Exhausts (90% of people who have had a Spoon N1 and a few other N1 systems will attest to this)
2.) I Posted in your last Post that the Spoon N1 is designed to mount to an OEM B Pipe (And since the Spoon, Vision, & T1R B pipes use the same Lengths and flanges as an OEM system the OEM or Spoon N1 Axle Backs will bolt onto them.)
Old Apr 8, 2003 | 06:11 PM
YelLowITR's Avatar
why u putting those 2 totally different things together?!!?!?
Old Apr 8, 2003 | 06:14 PM
Mike M's Avatar
Founding Member
Default Re: mugen twin loop? spoon n1? (YelLowITR)
BTW Spoon N1 Vid Clip with interior and exterior sound as well as idle and driving
http://ipsracing.com/Mike/spoon_N1.wmv
Old Apr 8, 2003 | 07:56 PM
SamB's Avatar
New User
Default Re: mugen twin loop? spoon n1? (Mike M)
I have the Moogen and love it although it could be a little louder and the resonator does hang quite low.
Sam
Old Apr 8, 2003 | 08:01 PM
sslude's Avatar
Default Re: mugen twin loop? spoon n1? (SamB)
id go for mugen, IF i had the money
Old Apr 8, 2003 | 08:06 PM
jonas's Avatar
Default Re: mugen twin loop? spoon n1? (B2FiNiTY)
huh? Mugen Twin loop isn't a catback only system. its expensive as an axle back
Old Apr 8, 2003 | 08:19 PM
B2FiNiTY's Avatar
Default Re: mugen twin loop? spoon n1? (jonas)
For the Integra, it's catback.
Old Apr 8, 2003 | 08:21 PM
jonas's Avatar
oh wierd, my friend with a GS-R bought his axle back brand new.
but i see what you're saying, on king's site it's catback only.
Old Apr 8, 2003 | 08:49 PM
ITSUKA's Avatar
thx alot guys greatly appriciated i'll get the mugen but i need a hi flow cat cause theyguy the bought it off had a really bad system bad hi flow cat everything will any hi flow cat bolt on to the cat back mugen twin loop exhaust?
Old Apr 8, 2003 | 08:55 PM
skafia's Avatar
25 Year Member
Mike M.
I know compared to other N1 systems the Spoon N1 isn't that bad, but I am comparing it to the Mugen System in which he is comparing the two.
Also, you don't need to replace the B pipe, but if you want to make the two comparable, it would be suggested to buy an aftermarket B pipe as well.
Old Apr 8, 2003 | 09:19 PM
Mike M's Avatar
Founding Member
As far as Mugen Exhaust:
Integra - Catback
Civic Hatch - AxleBack
Civic Coupe and 4 Door - AxleBack
There is about a $150-200 difference between the Civic Hatch And Civic Coupe Exhausts as well. Not Sure why.
Old Apr 8, 2003 | 09:23 PM
Mike M's Avatar
Founding Member
What are you talking about? Spoon, T1R, & Vision B Pipes are Made to STOCK OEM Specs (Just Different size piping and components) so Basically you can replace Just the B Pipe in an OEM system.
The Bolt On Axlebacks are The SAME WAY. You do NOT need to replace the OEM B Pipe.
If your trying to say that Your better off replacing the OEM B Pipe for Performance, thats not always true. If you have a Stock or Mildly (Just I/H/E) Modded Integra there isn't much gain from replacing the B Pipe.
Old Apr 8, 2003 | 10:07 PM
skafia's Avatar
25 Year Member
What I am saying is that comparing the MUGEN Catback to a Spoon N1 Axleback won't work! Meaning the Mugen is a CATback and the Spoon is just an Axleback so if he got an aftermarket B pipe it would be easier to compare the two.
[Modified by skafia, 11:09 PM 4/8/2003]
[Modified by skafia, 11:10 PM 4/8/2003]
Old Apr 9, 2003 | 03:11 AM
itr-j's Avatar
mugen
FUJITSUBO
Old Apr 9, 2003 | 11:51 AM
Ill's Avatar
Ill
Default Re: mugen twin loop? spoon n1? Apexi World Sport?
I need to glom onto this as I have the same problem. I'm looking for something with good power specs for a mildly mod'd NA 98 USDM ITR (mostly street use with some track and autocross), but I want it to be Q-U-I-E-T.
Any additional recommendations on choosing an exhaust are appreciated. I heard the Apexi World Sport was popular, good, relatively inexpensive, and quiet. How does it compare to the Mugen?
I live outside a smog area, so I'm going to be installing a header (JDM 4-2-1?), test pipe (2.5"), H-T 2nd O2 sensor OBD II fooler circuit, and eventually an intake (Mugen if I have cash in time for the group buy).
I'd like to leave it setup so I can put a cat back in if they change the smog laws here in the future.
When I bought my R, it came with a Maxspeed exhaust.
Thanks in advance.
Old Apr 9, 2003 | 11:53 AM
Chris N's Avatar
Default Re: mugen twin loop? spoon n1? Apexi World Sport? (Ill)
Why are we even trying to compare a full catback to an axleback....
because they are made by Spoon and Mugen? x 100
This is just as dumb as the 'spoon vs. mugen' threads.
Old Apr 9, 2003 | 12:50 PM
Noe Kozz's Avatar
Default Re: mugen twin loop? spoon n1? Apexi World Sport? (Chris N)
If noise is your number one concern, I think you would be better off with mugen. I have the Spoon N1 with silencer, at idle it's quiet, almost stock sounding, but when jamming the throttle, it's a different story.
PeterVSays
Mar 28, 2013 09:07 AM
Justin Jones
Suspension & Brakes
Nov 23, 2008 02:05 PM
Projectjdm4
Nov 28, 2007 03:36 AM
aNaRcHyiNmYeK
Jun 2, 2002 11:56 AM
AllMotorITR
Apr 15, 2002 11:19 AM
