94 LS ATF Help
Old Apr 8, 2003 | 04:52 PM
Medek's Avatar
Default 94 LS ATF Help
Could anyone explainto me, or refer me to a site that can guide me through changing my Automatic Transimission Fluid in my 94 LS.. thanks
Old Apr 8, 2003 | 06:01 PM
Tweakmeister's Avatar
Default Re: 94 LS ATF Help (Medek)
http://www.helminc.com is the best guide (a shop manual)
sometimes on auto trannies you want to actually flush (or "wash") the fluid through...versus just draining the old stuff and replacing new. A machine is required for this (stealership).
Anyway though, yeah, get a manual so you know the torque specs, etc.
Old Apr 8, 2003 | 06:20 PM
mickey513's Avatar
Look behind the front passenger wheel against the engine and you'll notice a plug where you can fit a thin 3/8 ratchet into it. It's going to be a tight fit but the 3/8 ratchet will fit. Take off that plug and the trans fluid will come out. I recommend you jack up the car and put jackstands underneath, making it higher will give you more leverage in turning the ratchet. Refill from the top of the motor where you check/add trans fluid. It takes 3 qts of Dexron III fluid to do the ATF changed.
Roediep
Honda Fit
Feb 13, 2014 11:07 PM
Maurice24
Apr 30, 2010 12:39 PM
teggmann
Jun 16, 2007 05:26 AM
Adam_F123
Nov 25, 2005 11:05 AM
