Ac on Hybrid swap....Repost...
well i dont have an HF, but i'm pretty sure the compressor is the same on the DX which is what I did. HAsport makes b-series ac brackets for all model CRX's; it's 179.99 but usually on backorder, so be prepared to wait a little while. Bolts up fine, but you'll probably have to get a longer belt like I had to get. It uses your stock tensioner pulley as well, and all the bolts needed are provided.
I swapped a B18 in my 90 HF. Used the Hasport bracket. I just unbolted the compressor before removing engine. Then I rebolted it to the Hasport bracket already installed on the engine after lowering the engine in place. Did not have to recharge the system.
HTH
chris
HTH
chris
If it's backordered, you can get it here:
http://app1.hybridgarage.com/store/hgrstore.pl
And, yes - just unbolt the compressor & bracket (NOT the A/C lines!), then bolt up the new Hasport bracket to your swap & then bolt your old compressor (with the lines still attached) to the Hasport bracket. Fit & finish are excellent - not to mention the Hasport bracket is aluminum & weighs about one lb.
Lok1
Jul 26, 2018 09:01 AM
90 Si Hatch
Aug 13, 2011 10:12 PM
Renegade
Jan 28, 2005 07:39 AM
