89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!!
Old Apr 8, 2003 | 02:43 PM
*Boostwerks*'s Avatar
Default 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!!
I just took my first drive with this setup, and all I can say is wow! I am lowered about 2.5-3", and even going over very large bumps, the car isn't disrupted at all!
Skunk2 coil-over setup.
89 Accord Front shocks. Bilstein heavy duty's.
91 CRX Koni yellows (set on med. firmness).
The handling is great. The car doesn't get disrupted in the turns like it used to. With the old setup, hit the smallest bump and the car was hard to control. Now, it takes every turn smooth as hell, and just asks for more. I have kept the Bilstein rubber bump stops on the fronts, and therefore, has prevented the upper A arms from hitting.
All in all, I would reccomend this setup to ANYONE. The performance and ride is great!.
This is an old pic, but it gives a good idea how much I'm lowered.
[Modified by Bryson, 4:43 PM 4/8/2003]
[Modified by Bryson, 4:45 PM 4/8/2003]
Old Apr 8, 2003 | 02:47 PM
JCracer723's Avatar
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (Bryson)
nice yo !!
Old Apr 8, 2003 | 02:51 PM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (JCracer723)
Oh yeah, I guess I should say that I have a Jim Fab as well. I'm sure that helps a little...
Old Apr 8, 2003 | 03:12 PM
Hybrid Invasion's Avatar
Nice, man Good taste
Old Apr 8, 2003 | 04:08 PM
Toptul_Honda's Avatar
New User
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (Hybrid Invasion)
89 fronk shocks work? whats the difference? Did you use the accord forks too?
How come you didnt use konis up front?
Old Apr 8, 2003 | 04:33 PM
darkracer's Avatar
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (G2-Rex)
yeah what's the difference? why use the accord fronts? isn't the stroke different form the civics? , very interesting, want to know, cause getting my skunk2's pretty soon, GSR coils though, so a little rougher from the start. trying to decide on what shock, leaning towards bilsteins or tokico blues.
Old Apr 8, 2003 | 04:39 PM
crx(gator)'s Avatar
where and how much were the front shocks?
Old Apr 8, 2003 | 04:51 PM
DJ_SaNdOz's Avatar
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (darkracer)
the accord shocks add an ectra 1" of travel so your not riding on bumpstops. the rears are the same as oem tho.
Old Apr 8, 2003 | 09:05 PM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (dj_sandoz)
Exactly. Ham'ed hatch was the first person that I know of to make an informative post on this. His post is what lead me into doing this. he said in his post that he would reccomend this for JUST show people. I however beleive that anyone can do this.
I didn't get the Koni's up front because they were on back order for 4 months... Oh well. The bilsteins will do fine. I paid about 220ish for them.
Old Apr 8, 2003 | 09:06 PM
Nope just the shock. It's a direct bolt on. No mods nec, other than you can only use one of the brake line brakets. No prob.
Old Apr 8, 2003 | 09:55 PM
polycrx's Avatar
why just show people, just cause the car would ride low. What about performance, would you blow them out as easily as a regular oem shock. Whats the durability.Cause otherwise its something I would be interested also. tooo bad they are not adjustable.
Old Apr 8, 2003 | 10:14 PM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (polycrx)
well the shock is performing in it's specified range, and bilsteins from what I have found, do quite well with a higher spring rate (not as good as koni's I know).
I Don't know exactly why Ham'ed hatch only reccomended his setup for show, but I think it was because he was having the A arms hit the strut tower.
You are definetly less likely to blow out the Accord shock than the CRX shock, lowered at the same height.
Old Apr 8, 2003 | 10:43 PM
usdm_ED7's Avatar
nice...got any pics of your car lowered "2.5-3.0 in"
Old Apr 8, 2003 | 10:46 PM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (usdm_ED7)
well Here is an old pic. I was lowered ruffly 2.5" at the time...
It is definetly lower now, but I don't have a good pic. Tommarow I will defeintely try to get some new pics.
[Modified by Bryson, 12:47 AM 4/9/2003]
Old Apr 8, 2003 | 11:00 PM
customx_'s Avatar
New User
i found out that http://www.eshocks.com is the cheapest for bilsteins ($95 each + free shipping)
Old Apr 8, 2003 | 11:03 PM
customx_'s Avatar
New User
oh yea do the accords fit the 91 crx rears as well?
Old Apr 8, 2003 | 11:09 PM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (R:L1i77)
They do, but they don't have the lower nut welded to the strut. You could easily get around that however, by just going to the hardware store and buying 2 lock nuts.
I felt it would be eaiser for instillation/disassembily, if I went with the CRX rears.
Old Apr 9, 2003 | 05:01 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R:L1i77 &raquo;</TD></TR><TR><TD CLASS="quote">oh yea do the accords fit the 91 crx rears as well?</TD></TR></TABLE>
fyi, i don't think the accord rear struts give you any increased shock travel like they do on the fronts. i am not 100% sure about this, but i think that is what i read before.
Old Apr 9, 2003 | 06:17 AM
90da's Avatar
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (breaka_1_9)
Do you always have a problem with the control arms hitting the strut towers? Or was that just Ham's problem???? I want to know because I'm thinking of doing this but I don't want to cut my strut towers like he did.
Old Apr 9, 2003 | 10:49 AM
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (90ef)
Breaka...
Yeah the rear accords are the exact same length...nothing gained.
90ef...
I have yet to hear or feel the A arms hitting the upper strut mount. This was just Ham's problem mainly because he was lowered so far, and did not put on front bump stops.
If you keep the bump stops, and don't lower anymore than 2.5", you should be fine...
Old Apr 9, 2003 | 11:41 AM
PhatOptimo's Avatar
NICE
Old Apr 9, 2003 | 11:56 AM
slowman's Avatar
I took way too long
That looks really nice. May be something to do later when I get money.
Old Apr 9, 2003 | 06:07 PM
90da's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Breaka...
90ef...
If you keep the bump stops, and don't lower anymore than 2.5", you should be fine... </TD></TR></TABLE>
Cool, thanks. Well I guess I know what I am getting ordered tomorrow Now I have to try to find my old forks, right now I have GSR struts in the front and this crappy winter and being lowered about 2.5"-3" aren't a good combo.Damn potholes.
Old Apr 9, 2003 | 08:25 PM
FR-MOB: ThE bEe GuY's Avatar
how much did you get the shocks for by the way? I think i might just do this too
Old Apr 9, 2003 | 10:50 PM
SiR Kid's Avatar
New User
Default Re: 89 Bilstein Accord front/91 CRX koni yellow rears...It rides F**CKING NICE!!! (ThE bEe GuY)
I just went to Tokiko's site and they have Tokiko blues for the 89 Accord... just not the Illumina adjustables.. Oh well.
You said this was a BOLT ON installation, right? This might be my ticket to resolving alot of front end problems I've been experiencing...
