AEM or AXXIS Ultimate pads?
Old Apr 8, 2003 | 12:43 PM
supapoopa's Avatar
Default AEM or AXXIS Ultimate pads?
Ok i've spent the past hour searching for the best brake pads (daily driving), and I have come down to the AEM (nissin) pads and the Axxis Ultimate pads.
Tell me your opinion. Which would you go with?
SO far the best price i have come up with...
Axxis = 63.75
Aem = haven't really checked but should be in groupbuy.
I also will be getting some Brembo blanks later on.
Old May 20, 2003 | 02:58 PM
rocket3004's Avatar
Default Re: AEM or AXXIS Ultimate pads? (supapoopa)
I'm looking at getting either of these two pads... any input on which one you prefer and why?
Jin Yamato's Avatar
Default Re: AEM or AXXIS Ultimate pads? (rocket3004)
axxis..
Old May 20, 2003 | 03:09 PM
mantic6t9's Avatar
Default Re: AEM or AXXIS Ultimate pads? (Jin Yamato)
Axxis Ultimates. These are what i use. Contact Andie from http://www.cobaltfriction.com
Old May 20, 2003 | 03:27 PM
EGO's Avatar
EGO
Damn post ******.
I can give a little input on Ultimates (Axxis). I've had mine since 2-5-03 and they're still in decent shape. They're cracked, but in decent shape none-the-less. I can vouch pretty heavily for these pads. I installed them with new, stock rotors and ATE Super Blue at the same time. Huge, and I mean huge improvement over the old, stock pads. The hotter they got, the better the performance out of 'em grew. I did notice brake fade in the mountains though, but on the street, they're a terror. The thing I messed up on was the break-in. I think my method was over the top. Too much braking, not enough cool down etc. Basically, I blew it compared to what Cobalt recommends. I can't say that they would have better life, braking or less noise had I broken 'em in to Cobalt's liking though. I might buy 'em again. If I do, I'll stick to the recommendation to a "T"
Pro's:
-sticky as bloody hell on the street (compared to stock)
-good cold adhesion
-don't take much to heat 'em
-cheap
Con's:
-possible brake fade in mountainous areas
-noisy (could be related to faulty break-in)
-tendency to crack, possibly leading to failure (might be related to faulty break-in)
-will warp stock rotors if used like little ******
-lots of dust (but washes easily)
Modified by Ant Bishop at 10:27 PM 5/20/2003
Modified by Ant Bishop at 10:29 PM 5/20/2003
Old May 20, 2003 | 05:03 PM
dp's Avatar
dp
Can't tell you on the AEM's 'cause I haven't used them but I'm using the AXXIS:
1) Initial stopping is superb, fade resistant is WAY better than stock.
2) <U>Ocassionally</U> "squeal" or "screech" at very low speeds.
3) They do dust much more than stock.
4) Friendly to rotors.
5) On '99-'00 SI a little modification to the front set is necessary but is a minor job.
These are my personal opinions on pads used for daily driving only, no track use.
Old May 20, 2003 | 06:58 PM
kommon_sense's Avatar
Default Re: AEM or AXXIS Ultimate pads? (dp)
I'm running AEM pads front and rear. The rears are over a year old and the fronts are about 10months old. I had powerslots front/rear, but warped the fronts, so now I have brembo blanks up front. I'm also using ATE Type 200 brake fluid (same as superblue).
The AEM pads are a nice improvement over stock. Very little squealing. They produce a fair amount of dust, but not a big deal if you wash the car every 2wks or so and the dust comes off without much of a fight. I'm happy with the pads and they are a good choice for street.
ek_will's Avatar
they dust more then stock!?
Old May 20, 2003 | 06:59 PM
Krnbk2's Avatar
using the ultimates as well and love them. its hard to explain but after putting them in i feel much more confident with my braking abilities over the oem pads
Old May 20, 2003 | 07:04 PM
pdiggitydogg's Avatar
Default Re: (krnbk2)
aem/nissin pads are great...ive had em for maybe 5mo
Old May 20, 2003 | 07:12 PM
Default Re: AEM or AXXIS Ultimate pads? (dash0n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dash0n &raquo;</TD></TR><TR><TD CLASS="quote">they dust more then stock!? </TD></TR></TABLE>
I'm not sure if the AEM pads dust more than stock. I had steelies on msot of the time. I put on my rims about the same time that the AEM pads were installed. So I can't really compare. However the AEM pads don't dust bad, but after 3-4 weeks, the wheels will start to look kinda bad/dirty. If you wash the car every 2-3 weeks, then the wheels will stay clean, you will hardly even notice the dust.
Old May 20, 2003 | 07:19 PM
WhyMe's Avatar
axxis pads are far better for performance than AEM pads (nissin OEM pads from Japan for many vehicles) So if you are looking to get a better all around street/performance pad then go for the axxis. The heat range is far better and durability is there.
Old May 21, 2003 | 05:20 PM
rocket3004's Avatar
Default Re: AEM or AXXIS Ultimate pads? (WhyMe)
I was just going to ask about the heat range of the ultimates.. i.e. the range of temperatures where braking is most effective. I know they are more of a "performance street/auto-x" pad, so are they not as effective in colder weather, and if so, how much less effective is it (that is to say, will it be an issue)?
Old May 22, 2003 | 12:45 AM
supapoopa's Avatar
Well to get back to this thread... i did go with the Axxis Ulimates. All I can say is DAYUM. They grip way better then OEM. I did a pretty light break-in, stopping from 20, 30, then about 50 mph. Breaking is excellent. I haven't noticed any problems in fading after abuse through some curvey roads.
Overall a great set of pads for cheap. $45 off ebay.
only complaint is the dust, but like said before it cleans off very easily.
Old May 22, 2003 | 12:57 AM
KTeller8's Avatar
Default Re: (supapoopa)
check nopi.com
we got axis pads form them for bout 35 bucks
Old May 22, 2003 | 05:56 AM
00MRSi's Avatar
Default Re: (KTeller8)
Go with the Ultimates. Get them from Cobalt Friction.
Old May 22, 2003 | 06:22 AM
v4lu3s's Avatar
RTFM
i have aem pads on both my honda right now and used axxis metalmasters before. i like the aem as a street pad, though i would not want to use them on a track anywhere...they do dust more than stock but not as much as the metalmasters, i ahvent had a chance to try the axxis ultimates yet though.
Old May 22, 2003 | 12:23 PM
rocket3004's Avatar
I tried nopi.com
I could only find metalmasters on their site.
where else can I get the ultimates for cheaper that ~50 shipped?
deviant1
10
Feb 15, 2003 03:04 AM
X2BOARD
Jan 23, 2003 10:07 AM
gsrteg
Oct 17, 2002 06:11 PM
b18bfreak
May 22, 2002 08:05 AM
integra15
Feb 11, 2002 02:36 PM
