help with installing gauges?
Old Apr 8, 2003 | 10:53 AM
silveraccord01's Avatar
Default help with installing gauges?
hey, sorry if its off topic, but i want to ask if any of you know how to install the electrical installation? thanx
Old Apr 8, 2003 | 04:58 PM
iam7head's Avatar
Default Re: help with installing gauges? (silveraccord01)
autometer boost gauge?
autometer Air/fuel ration gauge?
electrical speedo gauge?
Old Apr 8, 2003 | 05:03 PM
lahight's Avatar
New User
Default Re: help with installing gauges? (iam7head)
probably indiglos
Old Apr 8, 2003 | 07:34 PM
O forgot to say that, reverse indiglo gauges
Old Apr 8, 2003 | 07:42 PM
iam7head's Avatar
okay....
just twist out of the blubs on top, stick one wire on one side and
the other wire on the other side.
flip the light switch->Indiglo light on=right wires
wont light up=switch them around.
easy as one too free
Old Apr 8, 2003 | 10:17 PM
so i just twist off the two bulbs on top and i won't need them? so it doesn't matter if its negative wirin or positive? thanx
Old Apr 8, 2003 | 10:32 PM
KTeller8's Avatar
no you dont need them, you have your indiglos to light up
also i cut off that little light and just twist wired mine there
Edit: when i had them in lol
[Modified by KTeller8, 1:32 AM 4/9/2003]
Old Apr 8, 2003 | 10:45 PM
iam7head's Avatar
Default Re: help with installing gauges? (KTeller8)
just slip it in, try not to alter the stock cluster.
be very very careful with the needle.
I use to have those indilgo gaugest too.
01-02 coupe got a those titanium color stock
Old Apr 9, 2003 | 12:11 PM
95sihb's Avatar
http://community.webshots.com/...Fnmto
the way i got my guage cluster to look like this was by removing 2 bulbs on my cluster that was it. no need to buy white face gauges............... i personaly dont like them . they dont look to bright in this picture but they are bright. all you really have to do is get to the cluster you dont even have to remove the cluster from the car . when you get to the cluster there will be 2 small bulbs on the top on the cluster take them off and thats it . if you want you can go get brighter bulbs like piia bulbs and replace the bulbs that are stock on the gauge cluster and it's brighter............ thats what i did
Old Apr 9, 2003 | 04:06 PM
i'm kinda worried about the right side of the gauges cause theres two needles the gas and the water temp. so can i move the needles like turn it in a certain position so that i can slide in the new ones easier? thanx
JDMB20TDA
Jun 11, 2006 12:01 PM
undagroundrican
Jan 12, 2006 03:57 PM
DOHC_EF
Dec 27, 2004 07:46 PM
rival12
Jun 2, 2004 08:17 PM
integrasi
Jul 11, 2003 07:31 PM
