SAFC / VAFC results
It got brought up in another post - but it's a good question and could use it's own post. At what point in modifying your car should you add in an AFC? What kind of gains have you gotten from your tuned SAFC/VAFC or whatever?
"The HKS AFR Type D (or Type L) is a fuel-adjusting device that regulates the Air / Fuel ratio on speed density applications by changing the airflow voltage output to the vehicles factory computer. Designed for vehicles that are lightly tuned (air cleaner, exhaust system, etc.) and need only slight fuel adjustment, the 12 setting adjustment indicator allows the user to richen or lean the stock fuel settings by approximately 1.0 A/R point in either direction (richer or leaner)."
http://www.hksusa.com/products/?id=631
http://www.hksusa.com/products/?id=632
B18C7
Apr 21, 2003 12:20 PM
