wheres my oil going?
Old Apr 8, 2003 | 10:48 AM
Vampyre's Avatar
Default wheres my oil going?
ok there is a oil knome in my car.
i was taking a corner pretty hard in vtec the other day. and when i was in that turn vtec shut off. so i was like ohh **** i just lost oil pressure. as soon as i go out of the turn vtec came back.
i pulled over right away to check oil. the dip stick is dry as a bone. wtf. so i called honda for a appoitment. put a whole quart of mobil 1 full syn before it it filled the dip to between the holes.
the car is not burining it that only smoke thats comming out of the car is when going to redline there is a puff of black not much just a puff. since i have no cat i would see oil buring i am thinking.
ok so honda looked at it and found nothing wrong with it. checked valves all seals. the car is not leaking one drop either. i have never had this problem with the car before. where is the oil going. or maybe honda did not fill it all the way last time???????
Old Apr 8, 2003 | 10:50 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: wheres my oil going? (Vampyre)
I always ran into that problem running synthetic oil.
Ryan
GRM Scott's Avatar
25 Year Member
cars with high piston speeds tend to wick oil out of the engine...Mobil 1 seems to be really good at finding its way into the exhuast. It's not really a bad thing, but you gotta check it regularly. I burn less now that i'm using good old castrol GTX....there's a number of threads on oil and oil consumption, search might yeild some.
rated_r's Avatar
maybe your drain **** isnt tigthen
Old Apr 8, 2003 | 10:54 AM
Vampyre's Avatar
Default Re: wheres my oil going? (rated_r)
my **** is fine thank you very much.
cool i never though of that with full syn. sweet nothing to worrie about.
Old Apr 8, 2003 | 11:08 AM
oryanh's Avatar
Same here... I'd have to say, I baby my R as much or more than anyone else here, and yet, I burn oil consistently.
Before my 00' R was stolen it too started to burn oil a bit. I thought I had not properly "broken in" the engine.
After getting another R, I knew I could avoid the oil problem by trying a different "break-in" method... nope.
I'm almost sure our cars are mechanically perfect... they just burn (synthetic) oil.
I switched from Mobil1 to Castrol, and burning is minimal, but still there.
Old Apr 8, 2003 | 11:18 AM
rizen's Avatar
Default Re: wheres my oil going? (oryanh)
I had this issue with my previous GSR except it was really bad with mobil 1 syn. I took it to Acura and they completely rebuilt the bottom end and the problem became worse after a proper break in by the techs themselves. Shortly after that they ordered a new shortblock and that took care of the problem. If the problem gets worse, keep taking it in and complaining. (I was loosing 1 quart every 500 miles) only hitting vtec on occasion.
[Modified by r1zen, 8:19 PM 4/8/2003]
Old Apr 8, 2003 | 11:20 AM
pleiades nutz's Avatar
I think it all depends on how much time you spend in vtec.
Old Apr 8, 2003 | 11:21 AM
rizen's Avatar
Default Re: wheres my oil going? (oRgy)
If I drove the car out of vtec for 1000 miles (boy is that hard) I wouldn't loose a drop of oil. Forgot to mention that...
TypeR 01 886's Avatar
that would be all day for me, but i dont burn much oil at all.
Old Apr 8, 2003 | 11:50 AM
Vampyre's Avatar
Default Re: wheres my oil going? (TypeR 01 886)
they told me if you DRIVE it then you will burn oil in the higher rpms.
Old Apr 8, 2003 | 11:52 AM
rizen's Avatar
Some oil consumption is normal. What is the rate you are loosing it at...
Meaning how often are you in vtec throughout a certain given mileage. I mean according to Honda they say per 3k miles one court consumed is normal.
Old Apr 8, 2003 | 12:43 PM
oryanh's Avatar
I bothers me that some on this board have replaced rings that result in zero oil loss.
But hey, they could be "unsure" since they went through so much trouble to resolve the issue anyway.
I'd say "my engine quit burning oil" too if I just spend a load on a rebuild.
not really.
Old Apr 8, 2003 | 12:47 PM
Dave-ROR's Avatar
My car burns none, even at track days with castrol gtx. 3000-5000 mile between changes and I stopped checking the level cause it never changes
M1 does have a history of disappearing in these cars though.
[Modified by dawhiteboy, 4:47 PM 4/8/2003]
Old Apr 9, 2003 | 04:19 PM
oryanh's Avatar
Default Re: wheres my oil going? (dawhiteboy)
poop
...another grey hair.
because you don't burn oil
Old Apr 9, 2003 | 05:07 PM
tecnic1's Avatar
I burn tons of M1...like a quart every 1500 miles daily driving. I just write it off to another one of those little things that makes owning an ITR a love/hate thing
Old Apr 9, 2003 | 05:13 PM
disordeR's Avatar
Default Re: (tecnic1)
here's VTEC ::RAR::
here's oil ::stammering in fear::
the end.
my engine loves to burn oil, when i run it hard. i've never had the problem you're having either and i always run synthetic. then again i always check my fluids before i run it at the track. always check your fluids before you know you're going to "push" your car.
Old Apr 9, 2003 | 05:28 PM
01-1293's Avatar
Default Re: (disordeR)
i have the same problem .......... sometimes when i'm taking a sharp *** corner in second gear vtec doesn't engage
TougeAccord
Honda Accord (2013 - 2015)
Sep 21, 2018 06:02 AM
lilrobie69
Mar 21, 2012 10:23 PM
BLU CIVIC
Dec 4, 2008 04:41 AM
AntMan401
Aug 23, 2006 09:38 AM
fuck honda-tech
Dec 4, 2003 09:16 AM
