HOW TO: Gunmetal/polished lip LS wheels
Old Apr 8, 2003 | 07:06 AM
E-Rok's Avatar
EPIC TUNING
Default HOW TO: Gunmetal/polished lip LS wheels
Due to numerous requests for a how to, here ya go:
1. Clean wheel thuroughly, lightly sand if desired.
2. Tape off lip. I started the lip right where the spokes end. It takes skill and patience as you need to get the tape to curve with the lip. It WILL tend to crease, which is fine, as long as it coveres the lip good.
3. after the lip is taped off, MAKE SURE all the tape is sticking down on the wheel, you dont want paint to get under it.
4. Apply primer, I used a light coat followed by a medium coat. you dont need a whole lot of primer, so dont overdo it.
5. Primer dries quick, give it about 5 minutes and apply paint. I used a light coat, followed by one thick coat. DONT OVER PAINT. all you need is enough to cover the wheels, not milions of coats. Make sure you paint in different directions to get the sides of the spokes as well. I used roughly one can for all 4 wheels...so that tells you how much you need.
6. Let paint dry for about 30 mintues, and apply clearcoat. I just put one thick coat on, enough to where it looked nice and glossy.
7. Let the clearcoat dry for about an hour before installation. I let them sit inside overnight to be safe.
thats it, your done
Old Apr 8, 2003 | 07:42 AM
EK22Tim's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (rewsnaeht)
Good write-up, and great results! My to you. Nice!
Hey, any idea how to clean up corrosion on a 94 GSR rim? I have some around the lip..
Old Apr 8, 2003 | 07:54 AM
E-Rok's Avatar
EPIC TUNING
Default Re: HOW TO: Gunmetal/polished lip LS wheels (EK22Tim)
you might be able to wetsand it, and then re-clearcoat the wheel, but I'm not really too sure.
Old Apr 8, 2003 | 07:59 AM
Vic Nyce's Avatar
looks good
Old Apr 8, 2003 | 09:40 AM
99ls's Avatar
this might help:
https://honda-tech.com/zerothread?id=456881
Old Apr 8, 2003 | 11:15 AM
TheJediMex's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (Vic Nyce)
looks good
i second that
Old Apr 8, 2003 | 11:39 AM
Kryptonite's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (JdmTeg98R)
great write up.....
only a 2 hour process?
any specific kind of paint?
[Modified by Kryptonite, 3:41 PM 4/8/2003]
Old Apr 8, 2003 | 11:59 AM
EK22Tim's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (99ls)
this might help:
[/QUOTE]
Thanks a LOT bro! That is what I'm looking for. Will that work on my machined surface GSR daisies? And what can you do for some spots on the rim where the very edge is kinda.. gone? Like, corroded off? Just little 1/4" spots, but..
Old Apr 8, 2003 | 12:01 PM
-BlueGSR-'s Avatar
awesome write up! and finished product as well...
Old Apr 8, 2003 | 12:07 PM
AVXHATCH's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (-BlueGSR-)
Old Apr 8, 2003 | 12:35 PM
b00sted4dr's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (B16A6rex)
Nice!!! What was the specific color?
Old Apr 8, 2003 | 05:59 PM
E-Rok's Avatar
EPIC TUNING
Default Re: HOW TO: Gunmetal/polished lip LS wheels (96Ls4dr)
i used dupli-color body shop paint in dark grey. used dupli-color primer and clear coat as well. and yea it took about 2-3 hours.
Old Apr 8, 2003 | 06:04 PM
KOALA YUMMIES's Avatar
Next time you change your tires ask for the adhesive wheel weights. I used to have the same wheels and the bash on wheel weights always took away from the look. Nice wheels though.
Old Apr 22, 2003 | 12:21 AM
cloproductions's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (KOALA YUMMIES)
nice how too
Old Apr 22, 2003 | 05:26 AM
MugenGTR's Avatar
nice!
Old Apr 22, 2003 | 02:25 PM
black sohc civic's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (MugenGTR)
looks good, thanks for the info
Old Apr 30, 2003 | 06:36 AM
IntEGNYC's Avatar
Default Re: HOW TO: Gunmetal/polished lip LS wheels (black sohc civic)
Im going to do this. Thanks for the inspiration
dth0ng69
Nov 3, 2009 07:09 PM
91Ef4dR
Jan 6, 2009 03:14 PM
fms1day
May 8, 2007 06:44 PM
SlowPokeEg
Apr 12, 2007 07:43 PM
Full Race A6
Apr 16, 2004 10:11 AM
