anyone install a moroso oil pan on there d16 motor?
Old Apr 8, 2003 | 05:38 AM
keithv's Avatar
Default anyone install a moroso oil pan on there d16 motor?
i put one on my ZC sunday and i had to remove a baffle b/c it was hitting the pickup. the baffle is removable but i was wondering why i had to remove it in the first place. why would moroso include a baffle you need to remove?
Old Apr 8, 2003 | 05:42 AM
drjondurst's Avatar
Default Re: anyone install a moroso oil pan on there d16 motor? (breaka_1_9)
I havnt done it or anything, but Im curious as to what the advantages are to having an other-than-stock oil pan.
Old Apr 8, 2003 | 05:59 AM
keithv's Avatar
Default Re: anyone install a moroso oil pan on there d16 motor? (drjondurst)
the moroso pan has baffling in it to keep the oil pressure up when cornering hard (in auto-x or road racing).
i managed to bang up my ZC header pretty bad so it rubs the stock oil pan. it rubbed enough to put a pin-sized hole in the pan. i got it welded and bashed it in some, but since i got the moroso pan with some other parts, i decided to put it on.
here are some pics of the pan (you will have to copy and paste the link into your browser):
http://www.geocities.com/breaka19/POS/Dsc00273.jpg
http://www.geocities.com/breaka19/POS/Dsc00274.jpg
http://www.geocities.com/breaka19/POS/Dsc00275.jpg
Old Apr 8, 2003 | 06:25 AM
spankenstein's Avatar
Nevermind, I found it.
[Modified by spankenstein, 3:26 PM 4/8/2003]
[Modified by spankenstein, 3:27 PM 4/8/2003]
Old Apr 8, 2003 | 06:55 AM
keithv's Avatar
Default Re: anyone install a moroso oil pan on there d16 motor? (spankenstein)
the moroso site sucks, so i usually go to http://www.summitracing.com to find part numbers. here is the pan i am running:
http://store.summitracing.com/partde...rt=MOR%2D20908
Old Apr 8, 2003 | 07:04 AM
CRzex's Avatar
New User
Is that the same baffling you had to remove?
Old Apr 8, 2003 | 07:14 AM
keithv's Avatar
Default Re: anyone install a moroso oil pan on there d16 motor? (CRzex)
well i am not 100% sure about that. this pic should help some:
you can see the baffled i removed is, well, removeable. under the baffle that i removed, you can see a cutout, that is where the tube from the oil pickup sits. there is no way to leave the baffle on and bolt the pan to the block (or so i think).
Old Apr 8, 2003 | 07:56 AM
Steve91's Avatar
This may be a dumb question, but are you using the stock pickup or the Moroso one? If your using the Moroso pickup, I would be pissed and give them a call to find out whats up with the fitment.
Old Apr 8, 2003 | 07:57 AM
keithv's Avatar
Default Re: anyone install a moroso oil pan on there d16 motor? (Steve91)
good idea steve i might just give moroso a call. not sure why i didn't think of that.
but yes i am running the moroso pickup as recommended.
josh0407
Aug 24, 2007 04:30 PM
lude98SH
Apr 19, 2007 07:03 PM
civickiller
May 17, 2003 08:35 AM
keithv
Jun 22, 2002 01:21 PM
karmannghia
Mar 23, 2002 05:27 PM
